“A filehandle becomes stale whenever the file or directory referenced by the handle is removed by another host, while your client still holds an active reference to the object. A typical example occurs when the current directory of a process, running on your client, is removed on the server (either by a process running on the server or on another client).”
umount and remount the nfs directory on duplicati system or mount with “noac” option.
From man nfs:
"To improve performance, NFS clients cache file attributes. Every few seconds, an NFS client checks the server’s version of each file’s attributes for updates. Changes that occur on the server in those small intervals remain undetected until the client checks the server again. The noac option prevents clients from caching file attributes so that applications can more quickly detect file changes on the server.
In addition to preventing the client from caching file attributes, the noac option forces application writes to become synchronous so that local changes to a file become visible on the server immediately. That way, other clients can quickly detect recent writes when they check the file’s attributes.
Using the noac option provides greater cache coherence among NFS clients accessing the same files, but it extracts a significant performance penalty. As such, judicious use of file locking is encouraged instead. The DATA AND METADATA COHERENCE section contains a detailed discussion of these trade-offs."
