I am trying to connect with a ssh-key, it works with bitwise but i can’t get duplicati to connect.
It gives this error
Failed to connect: error-id:SSHFailedToParseKeyFile, user-information:Failed to parse the keyfile, check the key format and passphrase. Error message was Invalid private key file.
By username i fill in the username from QNAP and password created by the ssh-hey
By advanced options i selected ssh-key and added sshkey:// before the key
Are you using the 2.2 stable release?
It has simplified the way you supply the public key, and you can now just paste in the public key in the advanced options on the SSH page.
You should not enter a prefix, just paste in the public key contents.
If you are using an older version of Duplicati, you need to also url-encode the key, which is a bit of a hassle.
