Hello,
I run duplicati on 2 systems, one Ubuntu 18.4 LTS and one Window 10; some backups to en external disk, some to a remote fileserver via SSH. It seems all(at least most) my occurences of the dreaded “Unexpected difference in fileset” errors occur with this SSH connection related error. This is what I find in the logs:
System.AggregateException: One or more errors occurred. ---> System.AggregateException: The channel "BackendRequests" is retired ---> CoCoL.RetiredException: The channel "BackendRequests" is retired
at CoCoL.Channel`1.<WriteAsync>d__32.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext()
---> (Inner Exception #0) System.AggregateException: The channel "BackendRequests" is retired ---> CoCoL.RetiredException: The channel "BackendRequests" is retired
---> (Inner Exception #0) CoCoL.RetiredException: The channel "BackendRequests" is retired
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()<---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> Renci.SshNet.Common.SshConnectionException: Client not connected.
at Renci.SshNet.Session.SendPacket(Byte[] packet, Int32 offset, Int32 length)
at Renci.SshNet.Session.SendMessage(Message message)
at Renci.SshNet.Channels.Channel.SendData(Byte[] data, Int32 offset, Int32 size)
at Renci.SshNet.Sftp.SftpSession.SendRequest(SftpRequest request)
at Renci.SshNet.Sftp.SftpSession.RequestWrite(Byte[] handle, UInt64 serverOffset, Byte[] data, Int32 offset, Int32 length, AutoResetEvent wait, Action`1 writeCompleted)
at Renci.SshNet.SftpClient.InternalUploadFile(Stream input, String path, Flags flags, SftpUploadAsyncResult asyncResult, Action`1 uploadCallback)
at Duplicati.Library.Backend.SSHv2.PutAsync(String remotename, Stream stream, CancellationToken cancelToken)
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadFileAsync>d__17.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadBlockAndIndexAsync>d__15.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()
---> (Inner Exception #0) Renci.SshNet.Common.SshConnectionException: Client not connected.
at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()<---
I have 2 questions about this:
- How is a disconnect to the backend handled? First of all, the way this failure is reported seems very much like an unhandled error. The backup or even delete and repair db operations seems to fail with just “One or more errors occured” message (popup in UI), without any helpful information. When going to the backup and looking at the logs about a specific backup, this type of errors isn’t mentioned there, it’s only mentioned in the general logs. Also, it does sound a bit odd to me that a file upload (or download) should fail in just 1 attempt. I consider it “normal” that connections get interrupted once in a while, especially large file transfers, that’s why we use tools that have resume support. So it’s a bit odd the entire operations fails just due to 1 disconnect.
- I now have a hunch that the “Unexpected difference in fileset” error occurs each time a backup operation did not complete due to this error. Does that seem plausible to anyone more familiar with the internals of Duplicati2?
