currently running
- Duplicati - 2.0.4.34_canary_2019-11-05
- Windows 7
Some large files are not backed up.
There is no exclude setting used.
I don’t find those large files in the restore list.
How is that possible?
currently running
Files may be skipped if they are locked/in-use, and you are not using snapshots. Do you get any warnings in the backup job about files being skipped?
I don’t get warnings about those large files, that they are skipped.
Those are compressed files, which extension is listen in “default_compressed_extensions.txt” file.
Would it result file skipping?
My bad.
I excluded the extension in Filters, and I forgot it.
Thread can be deleted.
Only you can delete it
