I use Duplicati v2.0.5.1_beta_2020-01-18 with Docker (linuxserver build). I run it as root user so as I can backup all of my stuff from my working station.
I use a script to pass the backup reports to my IRC server:
I read many threads (httpx://forum.duplicati.com/t/duplicati-and-telegram/6282/16, httpx://forum.duplicati.com/t/where-does-script-output-go-to-difference-between-before-and-after/9571, httpx://discourse.linuxserver.io/t/setup-a-run-script-after-in-duplicati/1303/12, httpx://duplicati.readthedocs.io/en/latest/06-advanced-options/#run-script-after) but I can’t figure out how to pass the report to my script.
Another option for reporting is to use https://www.duplicati-monitoring.com. You use this in conjunction with the --send-http-url Duplicati option, and it gives you a single dashboard for all your Duplicati installs and backup jobs.
Yep read about it but I don’t want to use such a service, I’d prefer self-hosting (saw Github but too much work for my needs atm). And I stil IRC for many logs outputs.
