[Solved] Failed to connect: Only http or https scheme is allowed in 2.0.4.10_canary_2018-12-29
#1
Good afternoon, I’m here again because of a problem I’m having with the 2.0.4.10_canary_2018-12-29 connecting with OneDrive.v2.
Last week all my servers that use OneDrive stopped working, so by searching the forum I discovered that in order to get back to work it was necessary to change the server to OneDrive.v2, after making this change, on one of the servers I updated to 2.0 .4.10_canary_2018-12-29.
After this update I was manually backing up my server and the following error is occurring: “Failed to connect: Only http or https scheme is allowed”
Would anyone have any idea of the cause? If I swap the server for Mega.nz or another works, only the OneDrive.v2 that is experiencing the error.
#2
The log:
System.ArgumentException: Only http or https scheme is allowed
at System.Net.Http.HttpRequestMessage.set_RequestUri (System.Uri value) <0x4051e060 + 0x0010b> in :0
at System.Net.Http.HttpRequestMessage…ctor (System.Net.Http.HttpMethod method, System.Uri requestUri) <0x4051def0 + 0x0002b> in :0
at System.Net.Http.HttpRequestMessage…ctor (System.Net.Http.HttpMethod method, System.String requestUri) <0x4051d970 + 0x000a3> in :0
at Duplicati.Library.Backend.MicrosoftGraphBackend.SendRequest[T] (System.Net.Http.HttpMethod method, System.String url) <0x4051d8d0 + 0x0004b> in :0
at Duplicati.Library.Backend.MicrosoftGraphBackend.Get[T] (System.String url) <0x4051d840 + 0x0003f> in :0
at Duplicati.Library.Backend.MicrosoftGraphBackend.Test () <0x4051d3d0 + 0x0005b> in :0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) <0x40512d80 + 0x003e0> in :0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) <0x40512a10 + 0x001e7> in :0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) <0x404a58b0 + 0x01042> in :0
#3
Is this running under Mono (i.e. OS is not Windows?). Trying to look that up found possible source here although I’m not familiar enough with the design to know exactly why it’s complaining, especially as it did.
Can you get any sort of new destination up on OneDrive v2. at least to the point of a “Test connection” working? Please keep it simple, avoiding non-alphanumeric characters, which might be having problems.
#4
Yes, I am using Ubuntu 14.04 and this job previously ran with OneDrive.v1 normally, only after it was deactivated and the migration to v.2 that the problem appeared.
I can use GoogleDrive and Mega normally, the problem is that my OneDrive account which is where I have 1TB of storage I can not connect … The strange thing is that I have an EQUAL VPS in the same provider (Vultr) where the migration of OneDrive .v1 for OneDrive.v2 worked perfectly. =/
#5
Friends, I have 2 servers with the same application, the first one where Duplicati presents the error, I was execute the command to test if https works normally and returns:
root@princesinha-sorte:~# mono /usr/lib/duplicati/utility-scripts/TlsTest.exe  --web https://github.com
https://github.com
FAILED: #-2146233079
System.Net.WebException: Error: SendFailure (Error writing headers) ---> System.Net.WebException: Error writing headers ---> System.IO.IOException: The authentication or decryption has failed. ---> Mono.Security.Protocol.Tls.TlsException: The authentication or decryption has failed.
  at Mono.Security.Protocol.Tls.RecordProtocol.EndReceiveRecord (IAsyncResult asyncResult) <0x41bf0f40 + 0x0010b> in <filename unknown>:0
  at Mono.Security.Protocol.Tls.SslClientStream.SafeEndReceiveRecord (IAsyncResult ar, Boolean ignoreEmpty) <0x41bf0e80 + 0x0002b> in <filename unknown>:0
  at Mono.Security.Protocol.Tls.SslClientStream.NegotiateAsyncWorker (IAsyncResult result) <0x41bedaa0 + 0x00227> in <filename unknown>:0
  at System.Net.WebConnection.EndWrite (System.Net.HttpWebRequest request, Boolean throwOnError, IAsyncResult result) <0x41bf2770 + 0x00207> in <filename unknown>:0
  at System.Net.WebConnectionStream+<SetHeadersAsync>c__AnonStorey1.<>m__0 (IAsyncResult r) <0x41bf2070 + 0x0013b> in <filename unknown>:0
  at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x41bdefb0 + 0x0019f> in <filename unknown>:0
  at System.Net.HttpWebRequest.GetResponse () <0x41bd9640 + 0x00053> in <filename unknown>:0
  at TlsTest.GetWebPage (System.String url) <0x41ba21e0 + 0x0028c> in <filename unknown>:0
  at TlsTest.Main (System.String[] args) <0x41b98100 + 0x007ef> in <filename unknown>:0
On the other server, which I configured exactly the same way:
root@www1-pardal:~#  mono /usr/lib/duplicati/utility-scripts/TlsTest.exe  --web https://github.com
https://github.com
Does anyone know how to solve it?
Ubuntu 14.04 (I’m going to have to upgrade, however the problem is that the application only runs on that particular version, I’m waiting for the developers to update).
#6
I was able to solve the problem. I do not know why, but the mono version was making it not work correctly, I upgraded the mono according to the following tutorial and it worked: Download - Stable | Mono
Problems using test-filter
#7
Thanks for letting us know what solved this. I marked that as the solution. I hope your next Ubuntu goes well.
