SOLVED: Building installer using source is not working VS2017
Hi, I am trying to build using the build-msi.bat however I am getting an error. I have tried both cmd and vs 2017 dev cmd.
I’m sure its something I am doing, any help would be appreciated.
UPDATE: problem fixed when i installed wix tools vs extension
error
 The system cannot find the file specified.
Could Not Find C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\Duplicati.msi
Could Not Find C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\Duplicati-32bit.msi
'"vsvars32.bat"' is not recognized as an internal or external command,
operable program or batch file.
7-Zip 18.01 (x64) : Copyright (c) 1999-2018 Igor Pavlov : 2018-01-28
Scanning the drive for archives:
1 file, 16381982 bytes (16 MiB)
Extracting archive: package.zip
Path = package.zip
Type = zip
Physical Size = 16381982
Everything is Ok
Folders: 43
Files: 624
Compressed: 16381982
Microsoft (R) Build Engine version 15.5.180.51428 for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
Building the projects in this solution one at a time. To enable parallel build, please add the "/m" switch.
Build started 01/03/2018 14:26:06.
Project "C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.sln" on node 1 (defa
ult targets).
ValidateSolutionConfiguration:
  Building solution configuration "Release|x64".
Project "C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.sln" (1) is building
 "C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.wixproj" (2) on node 1 (def
ault targets).
C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.wixproj(72,3): error MSB4019:
 The imported project "C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\Microsoft\WiX\v3.x\Wix.ta
rgets" was not found. Confirm that the path in the <Import> declaration is correct, and that the file exists on disk.
Done Building Project "C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.wixpro
j" (default targets) -- FAILED.
Done Building Project "C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.sln" (
Build FAILED.
"C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.sln" (default target) (1) ->
"C:\Users\richa\Downloads\duplicati-master\duplicati-master\Installer\Windows\WixInstaller.wixproj" (default target) (2
9: The imported project "C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\Microsoft\WiX\v3.x\Wix.
targets" was not found. Confirm that the path in the <Import> declaration is correct, and that the file exists on disk.
    0 Warning(s)
    1 Error(s)
Time Elapsed 00:00:00.42
The system cannot find the path specified.
Build started 01/03/2018 14:26:07.
ult targets).
  Building solution configuration "Release|x86".
ault targets).
Build FAILED.
    0 Warning(s)
    1 Error(s)
Glad you got it working!
(I don’t know if you’re developing or just want to build your own copy, but but I went ahead and moved this to the “Developer” category - I hope you don’t mind.)
Thanks, I don’t mind at all
