Has anyone seen (or tried to make) a dashboard that would show the state of several Duplicati-running machines in a network?
For a SOHO situation, e.g.
See this for now
We have discussed it, and I plan to make a notification service that makes it possible to be notified when backups have not run. The interface would serve as a monitor-like overview of the backups, but without the ability for remote administration.
It seems that someone did actually do it:
cool. it’s going to drop a release “soon” which I guess in Github-speak is sometime between tomorrow and 2045?
If they release, I will test it.
BTW: A good way of showing your appreciation for a post is to like it: just press the button under the post.
If you asked the original question, you can also mark an answer as the accepted answer which solved your problem using the tick-box button you see under each reply.
All of this also helps the forum software distinguish interesting from less interesting posts when compiling summary emails.
I just tested the https://www.duplicati-monitoring.com/ the solution indicated above and really is what I would like to start. Of course one way to manage customers directly from the management would be very good, but only if it was in a personal infra and not a third party infra that I do not know so well.
If @kenkendk decides to do something native would be even better, however meanwhile I think the above solution can help solve the problem.
