Hello
I am using duplicati in version 2.0.3.11 enabled --snapshot-policy = On The first backup was performed successfully with this option enabled.
But backup backups are experiencing this problem.
The VSS feature is installed, my operating system is Windows 20012.
Follow the warnings.
DeletedFiles: 10
DeletedFolders: 0
ModifiedFiles: 502
ExaminedFiles: 1076969
OpenedFiles: 715
AddedFiles: 213
SizeOfModifiedFiles: 609608178
SizeOfAddedFiles: 6131349
SizeOfExaminedFiles: 80588454929
SizeOfOpenedFiles: 615844690
NotProcessedFiles: 0
AddedFolders: 97
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
ParsedResult: Warning
Version: 2.0.3.11 (2.0.3.11_canary_2018-09-05)
EndTime: 9/11/2018 12:07:22 AM (1536635242)
BeginTime: 9/11/2018 12:00:00 AM (1536634800)
Duration: 00:07:22.2925217
Log data:
2018-09-11 00:00:01 -03 - [Warning-Duplicati.Library.Main.Operation.BackupHandler-SnapshotFailed]: Failed to create a snapshot: Alphaleonis.Win32.Vss.VssSnapshotSetInProgressException: The creation of a shadow copy is already in progress.
at Alphaleonis.Win32.Vss.VssBackupComponents.StartSnapshotSet()
at Duplicati.Library.Snapshots.WindowsSnapshot…ctor(IEnumerable1 sources, IDictionary
2 options)
at Duplicati.Library.Snapshots.SnapshotUtility.CreateWindowsSnapshot(IEnumerable1 folders, Dictionary
2 options)
at Duplicati.Library.Main.Operation.BackupHandler.GetSnapshot(String sources, Options options)
2 options)
2 options)
