occasionally duplicati deletes the previous days backup on google drive.
I run backups every day at 05.00am.
I run 2.0.3.8 on macos but have seen this on previous versions and also on linux.
My retention settings: 1D:U,1W:1D,4W:1W,12M:1M
I also run the same job with B2 backend but has never seen the problem there.
This is part of the latest log (30 june 05.00) where it incorrectly deletes the previous day backup (29 june 05.00):
Warnings: []
Errors: []
TaskReader: null
DeleteResults: **
DeletedSets: [
Item1: 1
Item2: 2018-06-29 05:00:01 ** (1530241201)
] Dryrun: False
MainOperation: Delete
ParsedResult: Success
Version: 2.0.3.8 (2.0.3.8_canary_2018-06-28)
EndTime: 2018-06-30 05:12:10 (1530328330)
BeginTime: 2018-06-30 05:11:54 (1530328314)
Duration: 00:00:15.8072080
Messages: [
2018-06-30 05:00:00 +02 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2018-06-30 05:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2018-06-30 05:04:46 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (165 bytes),
2018-06-30 05:11:02 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b9df0f085712b4fb5ab6c5abd8d6173d3.dblock.zip.aes (49,91 MB),
2018-06-30 05:11:10 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b9df0f085712b4fb5ab6c5abd8d6173d3.dblock.zip.aes (49,91 MB),
