First I wan’t to say thanks for a nice piece of software. =)
I started my first run yesterday, not so big, only around 230GB that I’m backing up to Backblaze B2, but now after around 12 hours it’s only uploaded 24GB.
I have tested my speed against B2 and got around 60-80mbps.
The CPU and RAM is all good, could it be to small chunks? I set that to 50MB.
Upload a large file (i.e. 1GB or 5GB) via the web interface and manually time the upload.
For me, my home PC has been uploading to B2 from Duplicati at a rate of around 5 - 7GB/hr (on a 50 megabit FIOS connection, with a reported upload speed to Backblaze of about 25 megabits).
Damn, that was slow. I uploaded a 200MB file because 500MB was the max upload size from the web interface. That took a bit over 3 minutes and that give a speed around 8mbit/s. So I guess it’s not Duplicati that is slow but Backblaze is.
I made a ticket with backblaze and got this answer,
Hello,
This is due to the latency on the connection.
To upload more quickly you will want to get a software that supports multiple threads to upload the data.
That way you can use multi threads to bolster the upload output on the connection.
But if I’m setting the block size whould not make Duplicati to upload by more threads? I have blocksize of 50MB now but It just make one 50MB each time? It’s not working with multiple blocks?
I should have been more careful with the word “block”.
Duplicati does not support parallel uploads of files because it is hard to handle failures (the early upload fails, but the latter succeeds).
What I meant was that the uploads can be “chunked” where multiple chunks for the same file are uploaded in parallel (as suggested by B2). This requires a change in code.
Uploading multiple chucks should be the same speed as a large single file, unless there is a bottleneck with the B2 service. I cant see how threading this would make it faster?
True! As I understand the problem, the B2 servers limit the upload speed (either intentionally, or due to load), and the parallel uploads is meant to spread this out as you will be hitting different upload servers on their side.
Yes, you need to start and finalize the upload operation.
