It’s not really uploading yet, but busy (one core out of four) in SQLite preparing.
Normal backup needs about 3 seconds to get through about 6674 files like this:
2026-08-02 09:02:06 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-02 09:02:09 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:03.105
I’m in a test backup with 111,110 Files 11,110 Folders and it’s beginning like this:
2026-08-02 23:49:06 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
but it’s now 14 hours later, so something seems off. This is going to local C: drive.
This is second time, but Windows flaked out while I was looking at first. Rebooted.
2026-08-02 12:58:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-02 21:53:14 -04 - [Verbose-GetGpgProgramPath-gpg]:
2026-08-02 21:53:25 -04 - [Information-Duplicati.Server.WebServerLoader-ServerListening]: Server has started and is listening on 0.0.0.0, port 8304
2.3.0.4_stable_2026-07-09
The CPU symptom is it’s 25% busy on Windows 10, which is one CPU core on it.
System Informer shows usage at thread level, and some samples of its stack are:
0, e_sqlite3.dll!sqlite3_snapshot_free+0xa8d6d
1, e_sqlite3.dll!sqlite3_snapshot_free+0x9f392
2, e_sqlite3.dll!sqlite3_step+0x99
0, e_sqlite3.dll!sqlite3_backup_pagecount+0x23
1, e_sqlite3.dll!sqlite3_snapshot_free+0x27e30
2, e_sqlite3.dll!sqlite3_snapshot_free+0x27d29
3, e_sqlite3.dll!sqlite3_snapshot_free+0x26589
4, e_sqlite3.dll!sqlite3_snapshot_free+0x3532c
5, e_sqlite3.dll!sqlite3_snapshot_free+0xabf46
6, e_sqlite3.dll!sqlite3_snapshot_free+0x9f392
7, e_sqlite3.dll!sqlite3_step+0x99
That doesn’t have the C# view, but dnSpy debugger does, to go along with that:
Native
NextResult
ExecuteReader
ExecuteReaderAsync
WriteFileset
It seems to be running _commandText of:
"\n SELECT\n \"G\".\"BlocksetID\",\n \"G\".\"ID\",\n \"G\".\"Path\",\n \"G\".\"Length\",\n \"G\".\"FullHash\",\n \"G\".\"Lastmodified\",\n \"G\".\"FirstMetaBlockHash\",\n \"H\".\"Hash\" AS \"MetablocklistHash\"\n FROM (\n SELECT\n \"B\".\"BlocksetID\",\n \"B\".\"ID\",\n \"B\".\"Path\",\n \"D\".\"Length\",\n \"D\".\"FullHash\",\n \"A\".\"Lastmodified\",\n \"F\".\"Hash\" AS \"FirstMetaBlockHash\",\n \"C\".\"BlocksetID\" AS \"MetaBlocksetID\"\n FROM\n \"FilesetEntry\" \"A\",\n \"File\" \"B\",\n \"Metadataset\" \"C\",\n \"Blockset\" \"D\",\n \"BlocksetEntry\" \"E\",\n \"Block\" \"F\"\n WHERE\n \"A\".\"FileID\" = \"B\".\"ID\"\n AND \"B\".\"MetadataID\" = \"C\".\"ID\"\n AND \"C\".\"BlocksetID\" = \"D\".\"ID\"\n AND \"E\".\"BlocksetID\" = \"C\".\"BlocksetID\"\n AND \"E\".\"BlockID\" = \"F\".\"ID\"\n AND \"E\".\"Index\" = 0\n AND (\n \"B\".\"BlocksetID\" = @FolderBlocksetId\n OR \"B\".\"BlocksetID\" = @SymlinkBlocksetId\n )\n AND \"A\".\"FilesetID\" = @FilesetId\n ) \"G\"\n LEFT OUTER JOIN \"BlocklistHash\" \"H\"\n ON \"H\".\"BlocksetID\" = \"G\".\"MetaBlocksetID\"\n ORDER BY\n \"G\".\"Path\",\n \"H\".\"Index\"\n
but seemingly this is one of the queries that escapes the Duplicati profiling log.
Looking in a 2.3.0.108_canary_2026-07-20, I don’t see this sort of query either.
is my guess at where it is per debugger data, but it’s not yet in the looping part.
It’s not busy with the job database or dup-* temporaries, per Process Monitor.
It’s interacting more with the server database, every 5 minutes or so, maybe for
"SELECT \"ID\", \"Tags\", \"Time\", \"Repeat\", \"LastRun\", \"Rule\" FROM \"Schedule\" "
read from NextResult, but I took off that breakpoint as it was being false-positive.
I left one in to see if it ever hit ReadAsync, but in quite a few hours it has not yet.
The test here was adding above mentioned folder to a backup of single short file.
I haven’t tried variations yet. Wondering about other things to look into in this run.
Next run might test deeper test subtree, e.g. 11,110 Files (0 length) 1,110 Folders
Still taking up a quarter of a quad CPU. Used about 32 hours of core (probably a
little devoted to work before this test). Debugger position unchanged, no spewing
related to this in debugger output window (getting token errors, but likely normal).
TrayIcon is batch-file launched, sometimes shows terminal messages. None now.
Finding nothing relevant in event logs. Had hope of debug log output from seeing:
but DebugView isn’t showing any from Duplicati, only from some other programs.
Profiling log has usual UnobservedTaskException, WebsocketInvalidToken noise.
Duplicati has these datafolder files:
File, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\control_dir_v2, Read data, Read attributes, Synchronize
File, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\control_dir_v2\lock_v2, Write, Read attributes
File, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\Duplicati-server.sqlite, Write, Read
File, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\server.2.3.0.4_stable_2026-07-09-win-x64-gui.log, Write, Read attributes
File, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\TZRHLRQVSV.sqlite, Write, Read
Section, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\TZRHLRQVSV.sqlite, Query, Map read, Delete, Read control, Write DAC, Write owner
File, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\TZRHLRQVSV.sqlite-shm, Write, Read
Section, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\TZRHLRQVSV.sqlite-shm, Query, Map read, Map write, Delete, Read control, Write DAC, Write owner
File, C:\Duplicati\duplicati-2.3.0.4_stable_2026-07-09-win-x64-gui\RUN\TZRHLRQVSV.sqlite-wal, Write, Read
and two open Temp files, one 0 bytes, one 232. It’s now Aug 4. Job DB files are:
Still spinning in SQLite, but other areas are failing. Some of this was in 2.3.0.3 too:
is the icon. Sometimes it recovers. This one’s been down hours. Web UI failed too.
It no longer responds to GET requests, except for OS TCP-level acknowledgment.
Something in server had been writing profiling log many times per second like this:
2026-08-04 08:17:31 -04 - [Error-Duplicati.WebserverCore.Notifications.WebsocketAccessor-WebsockSendFailure]: Failed to send websocket message
System.OperationCanceledException: The operation was canceled.
---> System.ObjectDisposedException: Cannot access a disposed object.
Object name: 'System.Net.WebSockets.WebSocket'.
at System.Net.WebSockets.ManagedWebSocket.WriteFrameToSendBuffer(MessageOpcode opcode, Boolean endOfMessage, Boolean disableCompression, ReadOnlySpan`1 payloadBuffer)
at System.Net.WebSockets.ManagedWebSocket.SendFrameFallbackAsync(MessageOpcode opcode, Boolean endOfMessage, Boolean disableCompression, ReadOnlyMemory`1 payloadBuffer, Task lockTask, CancellationToken cancellationToken)
at System.Net.WebSockets.ManagedWebSocket.CreateOperationCanceledException(Exception innerException, CancellationToken cancellationToken)
at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1.AsyncStateMachineBox`1.ExecuteFromThreadPool(Thread threadPoolThread)
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
at System.Threading.Thread.StartCallback()
at Duplicati.WebserverCore.Notifications.WebsocketAccessor.SendData[T](SubscriptionService key, T data, IEnumerable`1 connections)
Interestingly, that’s the last entry in server log file, even though it’s 2.5 hours later.
I think I’m going to have to kill the process, but I was tiring of waiting for it anyway.
EDIT 3:
Debugger shows similar view from when things went from bad to worse in server:
I think I saw some reliability changes go in recently that this Stable doesn’t have.
The TrayIcon x in it doesn’t seem to happen in a 2.3.0.108_canary_2026-07-20,
so this new info is sort of informational. I’d like focus to be on the original failures.
EDIT 4:
Testing with different initial backup and smaller trees on second. Original short.txt
file in first backup was the character 1 followed by CR and LF. New A.txt is just A.
PASS short.txt and level 5 C:\tree\000000\000000\000000\000000\000000\
PASS short.txt and level 4 C:\tree\000000\000000\000000\000000\
FAIL short.txt and level 3 C:\tree\000000\000000\000000\
FAIL A.txt and level 3 C:\tree\000000\000000\000000\
Level 3 1,110 Files, 110 Folders
Level 4 110 Files, 10 Folders
Level 5 10 Files, 0 Folders
EDIT 5:
UploadNewFileset time, testing 2.3.0.108_canary_2026-07-20
Most of the tests use A.txt as first backup, timing second
110 Files, 10 Folders 0:00:00:00.171
440 Files, 44 Folders 0:00:00:10.180
880 Files, 88 Folders 0:00:01:21.810
1100 Files, 110 Folders 0:00:02:36.891
1,110 Files, 110 Folders 0:00:02:39.780
Above looks like more than linear slowdown with more files
Don't take benchmark as done pristinely though. No restart
Huge difference, first backup versus second is interesting
Without A.txt as first backup
11,110 Files, 1,110 Folders 0:00:00:00.152
With A.txt as first backup
11,110 Files, 1,110 Folders still running after an hour
EDIT 6:
Still running after an overnight try for completion. About 9 hours elapsed time.
SQLite thread looks a little different compared to 2.3.0.4, with many unknown
addresses lower on the stack. The very top of stack bounces around as usual
0, e_sqlite3.dll!sqlite3_preupdate_depth+0x65cee
1, e_sqlite3.dll!sqlite3_preupdate_depth+0x5ef70
2, e_sqlite3.dll!sqlite3_step+0x95
3, ILStubClass.IL_STUB_PInvoke(SQLitePCL.sqlite3_stmt) + 0x8e <-- 0x7fff22270e0e
4, 0xeb78ffd5e0
5, 0x7fff22303ae8
6, 0x24ffb22f560
7, 0x240088dfaf0
8, 0x23ffd69c280
9, 0x1
Unsurprisingly, the Stop button and then the Abort button it becomes don’t work.
Probably going to do another process kill soon, but let me describe the data use.
It’s full of empty files with 10 per level, and 10 folders that go deeper recursively.
Eventually (it’s configurable, and I think I still have its Perl script) recursion ends.
I’m not sure what else to say or do, and I might open an issue pointing back here.
EDIT 7:
Because I have old Duplicati versions handy, and test is simple, I tested old ones.
I also checked if changes such as SQLite switch to Microsoft and WAL correlated.
2.1 and 2.2 Stable were OK. 2.3 was not, and problem worsened at SQLite swap.
From profiling logs, I’m thinking journal_mode=WAL came in with the new SQLite.
I’ve also wondered if PRAGMA optimize from after first backup might mislead the
query planner into slow plan after large growth in tables during the second backup.
I don’t think Duplicati runs that often, and running it often might face some issues
if done before commit. Current plan runs it at close, presumably after the commits.
Results at what I call level 3 of tree have often been a bit variable, maybe slowing.
To get more regression at 2.1.0.121_canary_2025-07-07, I raised source to level 2.
That’s the 11,110 Files 1,110 Folders level of the tree. See elsewhere for more info.
2.1.0.5_stable_2025-03-04
2026-08-06 11:39:39 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 11:39:39 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.285
2026-08-06 11:44:09 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 11:44:10 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.671
2.2.0.3_stable_2026-01-06
2026-08-06 12:03:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 12:03:32 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.189
2026-08-06 12:04:24 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 12:04:24 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.442
2.3.0.0_stable_2026-04-14
2026-08-06 12:10:53 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 12:10:53 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.011
2026-08-06 12:12:54 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
(killed after over two core-hours of CPU use)
2026-08-06 14:46:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 14:46:14 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.143
2026-08-06 14:47:54 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 14:50:37 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:02:43.028
With second backup at level 2 instead of level 3:
2026-08-06 17:25:06 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 17:25:06 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.150
2026-08-06 17:32:40 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
(killed after 14 hours, 16 core-hours of CPU)
2.1.0.120_canary_2025-06-24
2026-08-06 17:00:42 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 17:00:42 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.210
2026-08-06 17:02:43 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 17:02:43 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.369
2026-08-06 17:14:19 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 17:14:19 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.234
2026-08-06 17:17:47 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-06 17:18:09 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:21.382
EDIT 8:
2.3.1.0_beta_2026-07-28 on the level 2 test:
2026-08-07 11:10:58 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2026-08-07 11:10:58 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:00.012
2026-08-07 11:18:53 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
It’s now over 24 hours later and still at 25% CPU, so one core of a quad core CPU.
0, e_sqlite3.dll!sqlite3_preupdate_depth+0x67da9
3, ILStubClass.IL_STUB_PInvoke(SQLitePCL.sqlite3_stmt) + 0x8e <-- 0x7fff4336508e
EDIT 9:
Back to 2.3.0.108_canary_2026-07-20 to try --long-database-query-threshold.
Set it to 1m and let it query 5 minutes. No warning. The report on the oddity is here.
Killed process and went to look for the size of first backup that slows on the second.
Level 4 to level 2 was fine. So was level 5, which is the final folder in the tree, but a
file within the bottom folder caused the problem. This seems a very narrow problem.
One difference in new UI is that changing a subfile or subfolder to a parent folder is
prone to deleting the subthing. That doesn’t happen when first backup is elsewhere,
but I don’t know if it matters. A slow/stuck seems to happen whether or not it’s kept.
EDIT 10:
After pretty thorough forum testing, made it an issue, though it seems a bit obscure.
