But I found the problem. I used du to get the disk usage of the folders to be backed up. The partition is btrfs. Probably due to the COW nature of the filesytem, du reported just 4.2GiB (actual disk usage), for what is 400GiB (reserved space).
Does duplicati does deduplication? On file or block level?
