I’m trying to set up Duplicati with Sia using this guide:
When I run a small test backup all seems fine but Duplicati UI says source: 63MB, Backup 0 bytes / 0 Versions. And the file is not visible in Sia-Ui. When I run it a second time I get this error message:
"/renter/delete/test/duplicati-20190328T204758Z%2Edlist%2Ezip failed, response: {“message”:“API authentication failed.”} "
Yes, Sia changed their API authentication process recently. Duplicati version 2.0.4.16 or higher supports the correct API authentication. The blog post you’re following doesn’t have the necessary API authentication bits in place. I recommend reaching out for help in the Sia Discord if you need help getting it going.
Is Sia ready for personal computer backup? There were issues before in terms of Sia requiring a minimum file size of maybe 40 MB, and so all files were scaled up that amount, also maybe it would be expense to restore an entire archive in the event of a hard drive problem?
Is there any more detail on this available? My prior existing Sia test backup still fails, and the error messages contain language about API authentication, while at the same time no new options seem to be available for its configuration.
Is Sia ready for personal computer backup? There were issues before in terms of Sia requiring a minimum file size of maybe 40 MB, and so all files were scaled up that amount.
Sia still pads files to increments of 40MiB. However, when using Duplicati this limit doesn’t incur much waste since you can set the volume size as large as you want. We typically recommend a Volume size of 500MB or larger.
Sia has extremely inexpensive download bandwidth costs. The actual costs depend on the contracts your Sia daemon has, but they are usually a few cents/terabyte download.
What details do you need? You need to get the API password for your Sia installation and input it into Duplicati under “Server Password”. Feel free to join the Sia Discord for real-time help.
