I just rsync’d a completed (?) backup file set to another medium and I saw a file go by named
duplicati-[long_hex_string].dblock.zip.aes.part
Is that normal?
Is that normal?
That is not a file generated by Duplicati. I am guessing that the service that receives the files makes a temporary file called .part.
@Kahomono, in case others run into similar files, what was the destination of the sync?
I’m not super familiar with it, but is it possible it’s an rsync temp file?
Yes it is possible - I don’t have full logs from rsync
