Hello,
i am running Duplicati Duplicati - 2.0.7.1_beta_2023-05-25 on Ubuntu 22.04 LTS on a Raspberry PI 4B
Backing up to remote locations via ftp works fine.
When I try to backup to a mounted network drive (I tried with a windows share as well as with Fritzbox NAS) i receive a sharing violation
Backup started at 4/11/2024 1:21:32 PM
Checking remote backup ...
Listing remote folder ...
Fatal error => System.IO.IOException: Sharing violation on path /mnt/b
at System.IO.DriveInfo.GetDiskFreeSpace (System.String path, System.UInt64& availableFreeSpace, System.UInt64& totalSize, System.UInt64& totalFreeSpace) [0x00017] in <12b418a7818c4ca0893feeaaf67f1e7f>:0
at System.IO.DriveInfo.get_TotalSize () [0x00000] in <12b418a7818c4ca0893feeaaf67f1e7f>:0
at Duplicati.Library.Backend.File.get_Quota () [0x0000a] in <a11c194a0ed94b3ea73efea18edcd2ee>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable`1[T] protectedFiles) [0x00291] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.Collections.Generic.IEnumerable`1[T] protectedFiles) [0x00000] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0005f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00452] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.CommandLine.Commands.Backup (System.IO.TextWriter outwriter, System.Action`1[T] setup, System.Collections.Generic.List`1[T] args, System.Collections.Generic.Dictionary`2[TKey,TValue] options, Duplicati.Library.Utility.IFilter filter) [0x00119] in <81fea8e154eb4fd9aa8b06aac66d311a>:0
at Duplicati.CommandLine.Program.ParseCommandLine (System.IO.TextWriter outwriter, System.Action`1[T] setup, System.Boolean& verboseErrors, System.String[] args) [0x00342] in <81fea8e154eb4fd9aa8b06aac66d311a>:0
at Duplicati.CommandLine.Program.RunCommandLine (System.IO.TextWriter outwriter, System.IO.TextWriter errwriter, System.Action`1[T] setup, System.String[] args) [0x00002] in <81fea8e154eb4fd9aa8b06aac66d311a>:0
root@RPI4B:/#
I am able to access the target folder, create and remove files in the target folder.
Any idea what this is about?
Thanks, Stefan
