I’ve created a Docker image that I use to run Duplicati on my Linux systems. It’s been working well, so I wanted to share.
I do have a question about the LGPL. Does it require that I distribute the Duplicati source code since I’m distributing the binaries via the Docker image?
If you simply use the binary builds, then you have not modified the source, and you are free to distribute the binaries “as-is” (and the the source code is in the git repo anyway).
If you change stuff in the code (like custom logo, name, etc) it becomes more tricky. But since your own code is also open, I don’t think you need to worry.
When I first started the project, I couldn’t find any official Docker images. Or at least any that I thought were official. So I have no idea if mine offer anything better than an official image.
There aren’t any images linked to from the Duplicati download page. And I didn’t find the Docker Hub images until just now…
