Hello everyone,
I’m facing a perplexing issue while trying to establish an SFTP connection to my backup server and could really use your insights. Every attempt results in a “Failed to connect: Permission denied (publickey)” error. Here’s the detailed console output for reference:
duplicati-duplicati-1 | Renci.SshNet.Common.SshAuthenticationException: Permission denied (publickey).
duplicati-duplicati-1 | at Renci.SshNet.ClientAuthentication.Authenticate (Renci.SshNet.IConnectionInfoInternal connectionInfo, Renci.SshNet.ISession session) [0x0007e] in <969f1a9d1df4435bb9f5c99415b06766>:0
duplicati-duplicati-1 | at Renci.SshNet.ConnectionInfo.Authenticate (Renci.SshNet.ISession session, Renci.SshNet.IServiceFactory serviceFactory) [0x0001b] in <969f1a9d1df4435bb9f5c99415b06766>:0
duplicati-duplicati-1 | at Renci.SshNet.Session.Connect () [0x001e9] in <969f1a9d1df4435bb9f5c99415b06766>:0
duplicati-duplicati-1 | at Renci.SshNet.BaseClient.CreateAndConnectSession () [0x00053] in <969f1a9d1df4435bb9f5c99415b06766>:0
duplicati-duplicati-1 | at Renci.SshNet.BaseClient.Connect () [0x0001f] in <969f1a9d1df4435bb9f5c99415b06766>:0
duplicati-duplicati-1 | at Duplicati.Library.Backend.SSHv2.TryConnect (Renci.SshNet.SftpClient client) [0x0007b] in <b63dbdcd6b674560b8dea334a9cb2e39>:0
duplicati-duplicati-1 | at Duplicati.Library.Backend.SSHv2.CreateConnection () [0x0010e] in <b63dbdcd6b674560b8dea334a9cb2e39>:0
duplicati-duplicati-1 | at Duplicati.Library.Backend.SSHv2+<List>d__42.MoveNext () [0x0002c] in <b63dbdcd6b674560b8dea334a9cb2e39>:0
duplicati-duplicati-1 | at Duplicati.Library.Interface.BackendExtensions.TestList (Duplicati.Library.Interface.IBackend backend) [0x00017] in <9385304baed84a39b0ffc49ae589b75e>:0
duplicati-duplicati-1 | at Duplicati.Library.Backend.SSHv2.Test () [0x00000] in <b63dbdcd6b674560b8dea334a9cb2e39>:0
duplicati-duplicati-1 | at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x000b7] in <30a34d71126b48248d040dda634ddad9>:0
duplicati-duplicati-1 | at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x00091] in <30a34d71126b48248d040dda634ddad9>:0
duplicati-duplicati-1 | at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x00289] in <30a34d71126b48248d040dda634ddad9>:0
I’m currently using the latest Docker image of Duplicati, available at: Docker
To set things up, I’ve mounted my .config
directory to /config
within the container. Following that, I generated a new RSA key pair (id_rsa
and id_rsa.pub
) using ssh-keygen -m PEM -t rsa -b 4096
, placing the files in ./config/keys/
. The public key (id_rsa.pub
) has been added to the server.
Connecting directly via SSH using ssh -i <path_to_that_file> user@myip
works without any issues. Furthermore, when configuring the SFTP connection in Duplicati’s advanced settings, it prompts correctly for the passphrase when needed, indicating it’s reading the key file correctly. Yet, I still end up facing a “Permission denied” error.
I’m at my wit’s end trying to figure out why this is happening. Has anyone encountered a similar issue or have any suggestions on what might be going wrong?
Appreciate any help you can provide!
