I’ve been getting this “Value does not fall within the expected range” error on and off lately (since updating to 2.0.3.3 beta). The error seems to happen during a put retry loop (see Retry @ 10:42) which then succeeds and the backup seems to have a ParsedResult: Success (see Result @ 10:42) however after the a Fatal error is left (see Message @ 10:44) and the job is NOT considered successful (at least according to the job menu Last successful run:Last Saturday at 11:00 AM (took 00:33:28)).
I have two instances of the Retry error that did NOT result in a final Fatal error (3 days ago and a manual run just now) - but I have no idea why they worked while two other runs did not.
Any thoughts?
Apr 16, 2018 10:44 AM: Message
Fatal error
System.ArgumentException: Value does not fall within the expected range.
at Renci.SshNet.Session.WaitOnHandle (System.Threading.WaitHandle waitHandle, System.TimeSpan timeout) [0x00041] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Session.Renci.SshNet.ISession.WaitOnHandle (System.Threading.WaitHandle waitHandle) [0x0000d] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Channels.Channel.WaitOnHandle (System.Threading.WaitHandle waitHandle) [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Channels.Channel.Close () [0x00080] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Channels.ChannelSession.Close () [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Channels.Channel.Dispose (System.Boolean disposing) [0x0000f] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Channels.ClientChannel.Dispose (System.Boolean disposing) [0x0000c] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Channels.ChannelSession.Dispose (System.Boolean disposing) [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Channels.Channel.Dispose () [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SubsystemSession.Disconnect () [0x00053] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SubsystemSession.Dispose (System.Boolean disposing) [0x0000c] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Sftp.SftpSession.Dispose (System.Boolean disposing) [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SubsystemSession.Dispose () [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SftpClient.OnDisconnecting () [0x00017] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.BaseClient.Disconnect () [0x00006] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.BaseClient.Dispose (System.Boolean disposing) [0x0000c] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SftpClient.Dispose (System.Boolean disposing) [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.BaseClient.Dispose () [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Duplicati.Library.Backend.SSHv2.Dispose () [0x00008] in <29d74a8631ec474595c3d5eee75c41bf>:0
at Duplicati.Library.Main.BackendManager.Dispose () [0x00077] in <ae134c5a9abb455eb7f06c134d211773>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x008c4] in <ae134c5a9abb455eb7f06c134d211773>:0
Apr 16, 2018 10:43 AM: Result
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 0
ExaminedFiles: 46378
OpenedFiles: 0
AddedFiles: 0
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 54758243149
SizeOfOpenedFiles: 0
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults:
DeletedFileCount: 0
DownloadedFileCount: 0
UploadedFileCount: 0
DeletedFileSize: 0
DownloadedFileSize: 0
UploadedFileSize: 0
Dryrun: False
MainOperation: Compact
EndTime: 4/16/2018 10:42:31 AM (1523893351)
BeginTime: 4/16/2018 10:36:40 AM (1523893000)
Duration: 00:05:50.7963430
BackendStatistics:
RemoteCalls: 8
BytesUploaded: 1786
BytesDownloaded: 56768583
FilesUploaded: 2
FilesDownloaded: 3
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 1
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 1863
KnownFileSize: 44047373403
LastBackupDate: 4/14/2018 10:27:17 AM (1523719637)
BackupListCount: 155
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
DeleteResults: null
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20180404T153119Z.dlist.zip.aes
Value: [],
Key: duplicati-ic8d2a11e696f4f5dafa6c5ca634c0e68.dindex.zip.aes
Value: [],
Key: duplicati-b24068512e59e462c9bf5478999e7c8a4.dblock.zip.aes
Value: []
EndTime: 4/16/2018 10:43:45 AM (1523893425)
BeginTime: 4/16/2018 10:42:33 AM (1523893353)
Duration: 00:01:12.0398870
ParsedResult: Success <~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
BeginTime: 4/16/2018 10:07:22 AM (1523891242)
Duration: 00:36:23.2546050
Messages: [
Renaming "duplicati-bb2c4f170b67f4efc9cb43b0c129f3b3e.dblock.zip.aes" to "duplicati-bc043ffa4388d490f9aaf39f267e321c4.dblock.zip.aes",
Compacting not required,
removing file listed as Deleting: duplicati-bb2c4f170b67f4efc9cb43b0c129f3b3e.dblock.zip.aes
Warnings: []
Errors: []
Apr 16, 2018 10:42 AM: Message
Apr 16, 2018 10:42 AM: Retry
Operation Put with file duplicati-bb2c4f170b67f4efc9cb43b0c129f3b3e.dblock.zip.aes attempt 1 of 5 failed with message: Value does not fall within the expected range.
at Renci.SshNet.SubsystemSession.WaitOnHandle (System.Threading.WaitHandle waitHandle, System.Int32 millisecondsTimeout) [0x0004c] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Sftp.SftpSession.RequestRealPath (System.String path, System.Boolean nullOnError) [0x00072] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.Sftp.SftpSession.GetCanonicalPath (System.String path) [0x0000e] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SftpClient.InternalUploadFile (System.IO.Stream input, System.String path, Renci.SshNet.Sftp.Flags flags, Renci.SshNet.Sftp.SftpUploadAsyncResult asyncResult, System.Action`1[T] uploadCallback) [0x00042] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Boolean canOverride, System.Action`1[T] uploadCallback) [0x00017] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Action`1[T] uploadCallback) [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0
at Duplicati.Library.Backend.SSHv2.Put (System.String remotename, System.IO.Stream stream) [0x00012] in <29d74a8631ec474595c3d5eee75c41bf>:0
at Duplicati.Library.Main.BackendManager.DoPut (Duplicati.Library.Main.BackendManager+FileEntryItem item) [0x001fa] in <ae134c5a9abb455eb7f06c134d211773>:0
at Duplicati.Library.Main.BackendManager.ThreadRun () [0x000da] in <ae134c5a9abb455eb7f06c134d211773>:0
