I’m trying to set up Duplicati on a RPi 4 that I use at home as file server (Samba/NFS/FTP on 6TB drive) to backup up my stuff to my Google Drive.
Following the install guide, installing Duplicati needs Mono-Runtime, which I’ve installed the latest version of direct from their site rather than the Ubuntu Repo.
Installing Duplicati complains it’s missing a load of dependencies. Using APT to force install the needed dependencies what to install screen fulls of stuff, amounting to +350MBs of Mono.
That can’t be right, can it? Any ideas? I’m trying to keep the Pi as lean as possible.
Cheers!
I tried Duplicati on my Raspberry Pi 3, and the mono installation is unfortunately really big. The updates took forever and since it didn’t really solve the problem I had, I gave up eventually.
Cheers for that Rickard, just one more question.
I’ve installed all that Mono stuff on the Pi, and tried to set up the first backup, but I get no option to encrypt the backups. Is this correct? Or have I missed something in the install?
I did my test a while ago, but as far as I remember it worked just like it should. Well, part from that OneDrive for Business did not work (at the moment OD4B did not work on Debian/Raspberry and some NASes that built on Debian, I’m not sure if that problem is fixed in current release). I would expect the encryption to work as intended, double check the backup parameters and reinstall if needed.
