On step 2 (Destination) select a Storage Type of “Box.com”
Enter a “Path on server” of where you’d like your archive files stored - be sure to start it with a FORWARD “/” slash. Note that if the path doesn’t exist, Duplicati will create it for you
Click the “AuthID” link to open a new browser window and click the blue “Box.com login” button
Enter your login credentials and click the blue “Authorize” button
Click the blue “Grant access to box” button
When it goes blank, close the browser window and confirm Duplicati automatically populated your AuthID field
Click the “Text connection” button
If prompted to “Create folder?”, click the “Yes” button
If you do NOT get the “Success” message, go back and try again
Set up the rest of your backup as normal
Note that when logged into box.com it is normal to find “Duplicati Backup” listed in your Login Activity section of “Account Settings (menu) -> Security (tab)”.
