Hello
The subject of my topic is maybe not clear and I’ll try to explain
I configure backups on computers to send an http report with the option --send-http-level=all. It works great.
It’s nice to know when backups end with the ParsedResult “Success” but when they finish with the ParsedResult Warning or Fatal, I would like to know the reason why it issued (like it is shown on the local web interface).
Is it possible ?
Thanks for your replies
Using send-http-result-output-format=json you can get a detailed json with the LogLines: property containing the array of messages from the backup.
I use this but no Loglines appears :
--send-http-url=http://mywebserver
--send-http-result-output-format=Json
To ensure that this is not a local configuration issue, try using this site as a temporary target:
It shows the requests even if they are faulty somehow and this should at least let you know if the report is sending something.
