I have my send-http-levels set as such:
--send-http-level=Success,Warning
Because I do indeed want to send a ping if the job was successful or had warnings. This functionality works, but there are two issues:
The GUI for this setting (in the Duplicati Settings screen) does not support comma-separated values, despite the help text explicitly saying it’s possible. You have to switch to “edit as text” to enter multiple values. Here you can see what the GUI looks like once you have set multiple values in text mode:
And in text mode:
The comma-separated parameter appears to work perfectly. However, every single time a job runs, the following warning is issued:
2021-03-03 18:00:00 +00 - [Warning-Duplicati.Library.Main.Controller-OptionValidationError]: The option --send-http-level does not support the value "Success,Warning", supported values are: Unknown, Success, Warning, Error, Fatal, All
Running 2.0.5.1_beta_2020-01-18
