I lost internet while Duplicati was doing an initial backup to Jottacloud. This isn’t the first time this has happened. I just restart the docker container and it usually resumes backing up. This time I got an error saying Unexpected difference in fileset version 1.
What I did was rebuilt the database and verified data to no avail. I’m now getting a
Failed to connect: Error: SecureChannelFailure (Unable to read data from the transport connection: Connection reset by peer.)
error message.
I reconfigured my login credentials, I’m getting the same error when testing the connection.
Next, I installed Duplicati on another machine (Windows) and used the same login credentials and it worked.
Any suggestions? Here are the logs:
System.Net.WebException: Error: SecureChannelFailure (Unable to read data from the transport connection: Connection reset by peer.) ---> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer
at System.Net.Sockets.Socket.EndReceive (System.IAsyncResult asyncResult) [0x00012] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.Sockets.NetworkStream.EndRead (System.IAsyncResult asyncResult) [0x00057] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.Sockets.NetworkStream.EndRead (System.IAsyncResult asyncResult) [0x0009b] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.IO.Stream+<>c.<BeginEndReadAsync>b__43_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <254335e8c4aa42e3923a8ba0d5ce8650>:0
at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <254335e8c4aa42e3923a8ba0d5ce8650>:0
at Mono.Net.Security.MobileAuthenticatedStream.InnerRead (System.Boolean sync, System.Int32 requestedSize, System.Threading.CancellationToken cancellationToken) [0x00104] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at Mono.Net.Security.AsyncProtocolRequest.InnerRead (System.Threading.CancellationToken cancellationToken) [0x000ac] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x00093] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at Mono.Net.Security.AsyncProtocolRequest.StartOperation (System.Threading.CancellationToken cancellationToken) [0x0008b] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00252] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x00126] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.WebOperation.Run () [0x0009a] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <91935ad653254a93b9d73a9f8f2f7a2d>:0
at Duplicati.Library.Main.BackendManager.List () [0x00049] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x0000d] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0010b] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01033] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <c5f097a49c0a4f1fb0f93cf3f5f218b1>:0
