I would like to be able to use the “Object Storage” storage space of Scaleway which is an Amazon S3 type service.
It seems that my configuration of Duplicati is good, but I have an error when testing “Failed to connect: A WebException with status NameResolutionFailure was thrown.”
Here is the config of Duplicati:
Use SSL: Yes
Storage type: S3 compatible
Server: custom URL (https://s3.fr-par.scw.cloud)
Bucket name: (bucket name)
Region: Custom region value (fr-par)
Storage class: Standard
Folder path: backup
AWS Access ID: (generated access key)
AWS Access Key: (generated secret key)
Client library to use: Amazon AWS SDK
Can you help me ?
Thank you.
[edit] Duplicati - 2.0.5.1_beta_2020-01-18 in Linux Mint 19.3 Cinnamon
Not using SSL seems kind of dangerous. While Duplicati data is encrypted, I’d assume your login isn’t.
Is said to be based on Ubuntu 18.04, which has a mono that doesn’t do modern TLS. What does mono --version say? If below version 5, you might also be heading for some obscure glitches with Duplcati.
