I have Duplicati installed on 4 remote servers. However, I have not been able to find a way to get the backups to run unless a session is left on even if the session is disconnected. If the user is logged out the backups will not run. I installed the one service I found but from what I see it only starts the Duplicati when a user logs in.
Is there a way to run Duplicati completely unattended?
Duplicati service is by default run under system account. So if you fant that, you have to copy config from user appdata to system appdata in Windows folder - or run server under user some account
I’ve read and followed what ya’ll posted. Thank you very much for the insight and help in getting my issue(s) resolved. I will verify tomorrow that the backups worked on all my systems.
