I’m a relative novice but have read the various forums and I cannot find a way to run a script that uses the ‘run-script-before’ and a script after backup. Before my weekly backup of Debian I’m looking to stop Home Assistant running within VirtualBox and then restart it once the backup is completed but the error keeps saying ‘file not found’. My script is executable and I can run it locally on my Debian system or remotely via SSH
I’ve moved the executable script to another folder without a space in as well to rule this out but still the same error. I’m sure this must be a simple formatting error so any guidance/assistance greatly appreciated.
Did you then drop the single quotes? Are those there just to help the shell, so not in folder name?
They seem to have made it into the warning message. How exactly was that message obtained?
The script references are a little confusing. Is Duplicati backup itself being run from script or GUI?
If GUI, don’t quote (e.g. on Options screen) as you normally might for a shell. Give the actual path.
Thanks that was half of the problem solved, I then had to add in a line to the script which I found from a Google search and now it works so the end result is as follows:
As well as formatting as thankfully corrected it then had a user permissions issue. With the additional ‘export’ line in the script this has fixed the problem so now it successfully closes Home Assistant, takes a backup and then once completed it starts the VM again
