Run-script-after
Hello,
i have a problem with the “run-script-after” command. it isnt working for me. the script what i wanna execute is working if i run it manualy.
the “run script before” is working.
can i see somethere a logfile whats the problem is for the “run-script-after”?
i use Ubunthu 18.04
thx alot.
cheers,
Ice-Cue
Welcome to the forum @Ice-Cue
Output from run scripts gives some ideas on how to set up logging for debug.
Of course, you can instead instrument the script to echo debug clues to a file.
Depending on script exit code, you might get a warning or error, but you should see it, if it happened.
