I created a new task with the following properties:
(1) Run at Logon
(2) Run with the highest privileges checkbox selected
(3) Action: Start a program (and I configured it to the path to Duplicati.GUI.TrayIcon)
At the system boot and when I log in to Windows, Duplicati starts and it is minimized in the system tray.
Regards,
Lewis
This should run, however it runs as SYSTEM by default (one can change the user, as with any service). Sometimes the service must be put on “Startup type: Automatic (Delayed Start)” instead of “Automatic”, because it verifies updates thoroughly before launching them, and reading takes too long at boot time…
Perhaps because “you” is too few, and “simply” isn’t. Oddly, I didn’t notice any Feature request in the forum. Feel free to search further, and open one for discussion on exactly how you would propose it.
Another question is whether it should run as SYSTEM, thus have wide access to all users (defeating certain aspects of user-based protection of files), or should run as a given user, but with an elevation.
Update Windows installer to offer the choice of installing the Windows service #1738
looks like the feature request in GitHub, and points to some other pieces such as the tray icon which provides a certain amount of status that people like, but does not work if a GUI password is installed, because it can’t login to the server. There’s also an issue of Windows version updates clobbering the SYSTEM profile and moving it to Windows.old. So lots of issues to be sorted out, and low resources.
Duplicati Tray Icon Silently Dies with --no-hosted-server arg #3137 is on password and timing issues. Making things simple for the user is not a simple thing. Recently, reliability has been the main push… There are certainly a lot of competing feature requests and bugs too, both in the forum and in Issues.
Starting with the basic 3 (before TrayIcon), what are you seeing for WindowsService processes, and can manual start of the service manage to get them going? Sort alphabetically and watch duplicati processes.
I forget at what level the pause is implemented, but you can see if turning it off helps the service problem.
