"Retry failed after 6 tries. Retry settings can be adjusted in ClientOptions.Retry" in Azure Blob storage backend
Hi, I am running 2.2.0.0 via Docker on a Synology NAS. When running a ±35GB backup job to an Azure blob storage I get following errors:
Retry failed after 6 tries. Retry settings can be adjusted in ClientOptions.Retry or by configuring a custom retry policy in ClientOptions.RetryPolicy. (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.)
Job log (relevant part):
"2025-11-04 18:02:20 +00 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error\nAggregateException: Retry failed after 6 tries. Retry settings can be adjusted in ClientOptions.Retry or by configuring a custom retry policy in ClientOptions.RetryPolicy. (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.)",
"2025-11-04 18:02:21 +00 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed\nAggregateException: Retry failed after 6 tries. Retry settings can be adjusted in ClientOptions.Retry or by configuring a custom retry policy in ClientOptions.RetryPolicy. (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.)"
(a lot of repetitions :slight_smile: )
And the relevant part of the logfile:
—> (Inner Exception #5) System.Threading.Tasks.TaskCanceledException: The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.—> System.Threading.Tasks.TaskCanceledException: The operation was canceled.—> System.Threading.Tasks.TaskCanceledException: The operation was canceled.—> System.Net.Http.HttpRequestException: Error while copying content to a stream.—> System.IO.IOException: Unable to write data to the transport connection: Broken pipe.—> System.Net.Sockets.SocketException (32): Broken pipe— End of inner exception stack trace —at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)at System.Net.Security.SslStream.g__CompleteWriteAsync|157_1[TIOAdapter](ValueTask writeTask, Byte bufferToReturn)at System.Net.Security.SslStream.WriteAsyncChunked[TIOAdapter](ReadOnlyMemory1 buffer, CancellationToken cancellationToken)    at System.Net.Security.SslStream.WriteAsyncInternal[TIOAdapter](ReadOnlyMemory1 buffer, CancellationToken cancellationToken)at System.IO.Stream.g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken)at Azure.Core.RequestContent.StreamContent.WriteToAsync(Stream stream, CancellationToken cancellation)at Azure.Core.Pipeline.HttpClientTransport.HttpClientTransportRequest.PipelineContentAdapter.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken)at System.Net.Http.HttpContent.g__WaitAsync|56_0(ValueTask copyTask)— End of inner exception stack trace —at System.Net.Http.HttpContent.g__WaitAsync|56_0(ValueTask copyTask)at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken)at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)— End of inner exception stack trace —at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)at System.Net.Http.HttpClient.g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)— End of inner exception stack trace —at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts)at System.Net.Http.HttpClient.g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)at Azure.Core.Pipeline.HttpClientTransport.ProcessSyncOrAsync(HttpMessage message, Boolean async)at Azure.Core.Pipeline.HttpPipelineTransportPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory1 pipeline)    at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory1 pipeline, Boolean async)— End of inner exception stack trace —at Azure.Core.Pipeline.ResponseBodyPolicy.ThrowIfCancellationRequestedOrTimeout(CancellationToken originalToken, CancellationToken timeoutToken, Exception inner, TimeSpan timeout)at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory1 pipeline, Boolean async)    at Azure.Core.Pipeline.HttpPipelineSynchronousPolicy.InnerProcessAsync(HttpMessage message, ReadOnlyMemory1 pipeline)at Azure.Core.Pipeline.RedirectPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory1 pipeline, Boolean async)    at Azure.Core.Pipeline.RetryPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory1 pipeline, Boolean async)<—
Other backup jobs to the same Azure blob storage worked without a problem.
What can be the issue? I’m willing to test the timeout increase, but I cannot find the relevant setting.
Thanks in advance!
The documented timeouts that I can find in CLI 'help azure" are these. You could try them.
  --azure-access-tier
    Use this option to specify the access tier. If this option is not used, the server will choose a default access tier.
  --short-timeout = 30s
    The timeout in seconds for short operations like delete and create folder
  --list-timeout = 10m
    The timeout in seconds for listing files and folders
  --read-write-timeout = 30s
    The timeout in seconds for read and write operations. If no activity is detected in this interval, a timeout error is raised
This worries me because it was what OneDrive used to hit. I think it was HttpClient default.
The option to change that is gone, and a new timeout design is in. This might need the dev, however please change what you can, and see if stack trace is in About → Logs → Stored.
Thanks. I’ve tried setting all these options to 20m but still with the same result. Stack trace:
System.AggregateException: Retry failed after 6 tries. Retry settings can be adjusted in ClientOptions.Retry or by configuring a custom retry policy in ClientOptions.RetryPolicy. (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) (The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout.) ---> System.Threading.Tasks.TaskCanceledException: The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to write data to the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Security.SslStream.<WriteSingleChunk>g__CompleteWriteAsync|157_1[TIOAdapter](ValueTask writeTask, Byte[] bufferToReturn) at System.Net.Security.SslStream.WriteAsyncChunked[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteAsyncInternal[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.IO.Stream.<CopyToAsync>g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken) at Azure.Core.RequestContent.StreamContent.WriteToAsync(Stream stream, CancellationToken cancellation) at Azure.Core.Pipeline.HttpClientTransport.HttpClientTransportRequest.PipelineContentAdapter.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken) at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) --- End of inner exception stack trace --- at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Azure.Core.Pipeline.HttpClientTransport.ProcessSyncOrAsync(HttpMessage message, Boolean async) at Azure.Core.Pipeline.HttpPipelineTransportPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) --- End of inner exception stack trace --- at Azure.Core.Pipeline.ResponseBodyPolicy.ThrowIfCancellationRequestedOrTimeout(CancellationToken originalToken, CancellationToken timeoutToken, Exception inner, TimeSpan timeout) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.HttpPipelineSynchronousPolicy.InnerProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.RedirectPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.RetryPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) --- End of inner exception stack trace --- at Duplicati.Library.Main.Backend.BackendManager.Handler.ExecuteWithRetry(PendingOperationBase op, CancellationToken cancellationToken) at Duplicati.Library.Main.Backend.BackendManager.Handler.ReclaimCompletedTasks(List`1 tasks) at Duplicati.Library.Main.Backend.BackendManager.Handler.EnsureAtMostNActiveTasks(Int32 n, List`1 tasks) at Duplicati.Library.Main.Backend.BackendManager.Handler.EnsureAtMostNActiveTasks(Int32 uploads, Int32 downloads) at Duplicati.Library.Main.Backend.BackendManager.Handler.Run(IReadChannel`1 requestChannel) at Duplicati.Library.Main.Backend.BackendManager.WaitForEmptyAsync(CancellationToken cancellationToken) at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend(BackupDatabase database, BackupResults result, IBackendManager backendManager) at Duplicati.Library.Main.Operation.BackupHandler.RunAsync(String[] sources, IBackendManager backendManager, IFilter filter) at Duplicati.Library.Main.Backend.BackendManager.Handler.Run(IReadChannel`1 requestChannel) at Duplicati.Library.Main.Backend.BackendManager.Handler.<>c__DisplayClass14_0.<<RunHandlerAsync>b__0>d.MoveNext() --- End of stack trace from previous location --- at CoCoL.AutomationExtensions.RunTask[T](T channels, Func`2 method, Boolean catchRetiredExceptions) at Duplicati.Library.Main.Controller.<>c__DisplayClass22_0.<<Backup>b__0>d.MoveNext() --- End of stack trace from previous location --- at Duplicati.Library.Utility.Utility.Await(Task task) at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Func`3 method) at Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter) at Duplicati.Server.Runner.RunInternal(Connection databaseConnection, EventPollNotify eventPollNotify, INotificationUpdateService notificationUpdateService, IProgressStateProviderService progressStateProviderService, IApplicationSettings applicationSettings, IRunnerData data, Boolean fromQueue) ---> (Inner Exception #1) System.Threading.Tasks.TaskCanceledException: The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to write data to the transport connection: Broken pipe. ---> System.Net.Sockets.SocketException (32): Broken pipe --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Security.SslStream.<WriteSingleChunk>g__CompleteWriteAsync|157_1[TIOAdapter](ValueTask writeTask, Byte[] bufferToReturn) at System.Net.Security.SslStream.WriteAsyncChunked[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteAsyncInternal[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.IO.Stream.<CopyToAsync>g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken) at Azure.Core.RequestContent.StreamContent.WriteToAsync(Stream stream, CancellationToken cancellation) at Azure.Core.Pipeline.HttpClientTransport.HttpClientTransportRequest.PipelineContentAdapter.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken) at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) --- End of inner exception stack trace --- at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Azure.Core.Pipeline.HttpClientTransport.ProcessSyncOrAsync(HttpMessage message, Boolean async) at Azure.Core.Pipeline.HttpPipelineTransportPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) --- End of inner exception stack trace --- at Azure.Core.Pipeline.ResponseBodyPolicy.ThrowIfCancellationRequestedOrTimeout(CancellationToken originalToken, CancellationToken timeoutToken, Exception inner, TimeSpan timeout) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.HttpPipelineSynchronousPolicy.InnerProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.RedirectPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.RetryPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async)<--- ---> (Inner Exception #2) System.Threading.Tasks.TaskCanceledException: The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to write data to the transport connection: Broken pipe. ---> System.Net.Sockets.SocketException (32): Broken pipe --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Security.SslStream.<WriteSingleChunk>g__CompleteWriteAsync|157_1[TIOAdapter](ValueTask writeTask, Byte[] bufferToReturn) at System.Net.Security.SslStream.WriteAsyncChunked[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteAsyncInternal[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.IO.Stream.<CopyToAsync>g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken) at Azure.Core.RequestContent.StreamContent.WriteToAsync(Stream stream, CancellationToken cancellation) at Azure.Core.Pipeline.HttpClientTransport.HttpClientTransportRequest.PipelineContentAdapter.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken) at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) --- End of inner exception stack trace --- at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Azure.Core.Pipeline.HttpClientTransport.ProcessSyncOrAsync(HttpMessage message, Boolean async) at Azure.Core.Pipeline.HttpPipelineTransportPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) --- End of inner exception stack trace --- at Azure.Core.Pipeline.ResponseBodyPolicy.ThrowIfCancellationRequestedOrTimeout(CancellationToken originalToken, CancellationToken timeoutToken, Exception inner, TimeSpan timeout) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.HttpPipelineSynchronousPolicy.InnerProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.RedirectPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.RetryPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async)<--- ---> (Inner Exception #3) System.Threading.Tasks.TaskCanceledException: The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to write data to the transport connection: Broken pipe. ---> System.Net.Sockets.SocketException (32): Broken pipe --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Security.SslStream.<WriteSingleChunk>g__CompleteWriteAsync|157_1[TIOAdapter](ValueTask writeTask, Byte[] bufferToReturn) at System.Net.Security.SslStream.WriteAsyncChunked[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteAsyncInternal[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.IO.Stream.<CopyToAsync>g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken) at Azure.Core.RequestContent.StreamContent.WriteToAsync(Stream stream, CancellationToken cancellation) at Azure.Core.Pipeline.HttpClientTransport.HttpClientTransportRequest.PipelineContentAdapter.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken) at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) --- End of inner exception stack trace --- at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Azure.Core.Pipeline.HttpClientTransport.ProcessSyncOrAsync(HttpMessage message, Boolean async) at Azure.Core.Pipeline.HttpPipelineTransportPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) --- End of inner exception stack trace --- at Azure.Core.Pipeline.ResponseBodyPolicy.ThrowIfCancellationRequestedOrTimeout(CancellationToken originalToken, CancellationToken timeoutToken, Exception inner, TimeSpan timeout) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.HttpPipelineSynchronousPolicy.InnerProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.RedirectPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.RetryPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async)<--- ---> (Inner Exception #4) System.Threading.Tasks.TaskCanceledException: The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to write data to the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Security.SslStream.<WriteSingleChunk>g__CompleteWriteAsync|157_1[TIOAdapter](ValueTask writeTask, Byte[] bufferToReturn) at System.Net.Security.SslStream.WriteAsyncChunked[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteAsyncInternal[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.IO.Stream.<CopyToAsync>g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken) at Azure.Core.RequestContent.StreamContent.WriteToAsync(Stream stream, CancellationToken cancellation) at Azure.Core.Pipeline.HttpClientTransport.HttpClientTransportRequest.PipelineContentAdapter.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken) at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) --- End of inner exception stack trace --- at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Azure.Core.Pipeline.HttpClientTransport.ProcessSyncOrAsync(HttpMessage message, Boolean async) at Azure.Core.Pipeline.HttpPipelineTransportPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) --- End of inner exception stack trace --- at Azure.Core.Pipeline.ResponseBodyPolicy.ThrowIfCancellationRequestedOrTimeout(CancellationToken originalToken, CancellationToken timeoutToken, Exception inner, TimeSpan timeout) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.HttpPipelineSynchronousPolicy.InnerProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.RedirectPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.RetryPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async)<--- ---> (Inner Exception #5) System.Threading.Tasks.TaskCanceledException: The operation was cancelled because it exceeded the configured timeout of 0:01:40. Network timeout can be adjusted in ClientOptions.Retry.NetworkTimeout. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.Net.Http.HttpRequestException: Error while copying content to a stream. ---> System.IO.IOException: Unable to write data to the transport connection: Broken pipe. ---> System.Net.Sockets.SocketException (32): Broken pipe --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Security.SslStream.<WriteSingleChunk>g__CompleteWriteAsync|157_1[TIOAdapter](ValueTask writeTask, Byte[] bufferToReturn) at System.Net.Security.SslStream.WriteAsyncChunked[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.Net.Security.SslStream.WriteAsyncInternal[TIOAdapter](ReadOnlyMemory`1 buffer, CancellationToken cancellationToken) at System.IO.Stream.<CopyToAsync>g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken) at Azure.Core.RequestContent.StreamContent.WriteToAsync(Stream stream, CancellationToken cancellation) at Azure.Core.Pipeline.HttpClientTransport.HttpClientTransportRequest.PipelineContentAdapter.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken) at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) --- End of inner exception stack trace --- at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask) at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Azure.Core.Pipeline.HttpClientTransport.ProcessSyncOrAsync(HttpMessage message, Boolean async) at Azure.Core.Pipeline.HttpPipelineTransportPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) --- End of inner exception stack trace --- at Azure.Core.Pipeline.ResponseBodyPolicy.ThrowIfCancellationRequestedOrTimeout(CancellationToken originalToken, CancellationToken timeoutToken, Exception inner, TimeSpan timeout) at Azure.Core.Pipeline.ResponseBodyPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.HttpPipelineSynchronousPolicy.InnerProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline) at Azure.Core.Pipeline.RedirectPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async) at Azure.Core.Pipeline.RetryPolicy.ProcessAsync(HttpMessage message, ReadOnlyMemory`1 pipeline, Boolean async)<---
Log 20251105 1622.log.zip (29.4 KB)
The zipfile contains the exported log. What is interesting to see is that one single dblock file (duplicati-bc3f67a9f61f64e85960f6b882206b9b0.dblock.zip.aes for example) started uploading at 16:29 and got its timeout at 16:39, exactly 10 minutes after - whereas I’ve set the timeouts to 20 minutes. The 10 minutes would make sense however if there are 6 retries of 1:40 each - 6 times 1:40 is exactly 10 minutes. But there is no setting that could change that.
Other interesting thing is that this is the first time that I’ve done this backup since version 2.2.0.0, before this version I had no issues. Furthermore, other backups to Azure blob storage don’t have this problem. Blocksize is 50 MB, Dblock size is 200 MB; could be rather big but not sure if that could be the problem?
Are all the backups using 200 MB? The Azure library docs seems to show 100 second timeout:
RetryOptions.NetworkTimeout Property
The timeout applied to an individual network operations.
This might be what one can adjust, but I don’t see code in Duplicati that is able to do so.
Thie Azure libraries got changed to a new set for 2.2. I haven’t checked docs for old set.
Can you run some test backups, one with an even larger volume size, and one with smaller?
Alternatively, maybe you can try reducing traffic on upstream link on the troublesome backup.
2025-11-05 15:22:34 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20251105T134310Z.dlist.zip.aes (1.40 KiB)
2025-11-05 15:22:35 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20251105T134310Z.dlist.zip.aes (1.40 KiB)
2025-11-05 15:35:47 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b6f246a6bbcfd4182ac057dbb3129889c.dblock.zip.aes (198.89 MiB)
2025-11-05 15:36:07 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bd00b577315b6400f947b9ddf7f7763c1.dblock.zip.aes (198.80 MiB)
2025-11-05 15:36:19 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b1637b78dd052409dba6684c5e622197e.dblock.zip.aes (145.80 MiB)
shows a small upload worked, but starting three (and there might be more) big at once doesn’t.
  --asynchronous-concurrent-upload-limit (Integer): The number of
    concurrent uploads allowed
    When performing asynchronous uploads, the maximum number of
    concurrent uploads allowed. Set to zero to disable the limit.
    * default value: 4
If you reduce that to 1, maybe one 200 MB volume at a time can get uploaded in allowed time.
Regardless, this should get developer attention. I’m not sure which one will look into a change.
Thanks.
I have other backup jobs with Dblock size of 50MB and 500MB to the same Azure blob storage. The 50MB works nicely, for the 500MB I have to run some tests (the job runs regularly but the data is rarely changed so no uploads). Tell me if it’s relevant at this point.
I’ve tried the “asynchronous-concurrent-upload-limit” you mentioned (I set it to 1 instead of the default value of 4) and that works nicely.
Only slightly, but at this point it looks like an upload taking over 100 seconds can timeout.
Probably the devs should consider what default they like, and add an option for it anyway.
Hopefully the devs also have an Azure account and can do their own slow-upload testing.
Ok… would it help if I create an issue for it?
Yes.
That’s the best way to make sure it’s tracked. You can reference those back and forth.
It looks like someone created an issue. I’m pointing to here for history.
