I have 5 back-up versions of my drives. Now, I like to restore one of my drives (approx. 660 Gb), but after 2 days DUPLICATI shows still “temporary database will be created” (I have german language pack, so the translation is free).
Task Manager shows me still activity of DUPLICATI.
Ignoring empty remote files on restore, which speeds up recovery, thanks @Pectojin
If your progress bar is in the last 30% (and especially the last 10%), you might be hitting this old bug.
If so, and if you have nothing left of the previous drive (is that the case?) then latest Canary might do Restore more quickly. Canary is generally very latest and hasn’t had much testing, so could surprise.
I’m glad it worked. If you’re nervous about staying on Canary, you can change to Beta in Settings. Hopefully next Beta will be out soon (typically with an Experimental channel release as pre-Beta).
