Restore without DB
Hello,
in the Case of DB Lost why can a Data Restore proceeded or the DB new created?
By Duplicacy we don’t have any Local DB.
Many Thanks!
Many Greetings
Revan335
“The database is essentially a compact view of what data is stored at the remote destination, and as such it can always be created from the remote data. The only information that is lost if the database is recreated are log messages and the hashes of the remote volumes. The log messages are mostly important for error-tracing but the hashes of the remote volumes are important if the files are not encrypted, as this helps to ensure the backup integrity.”
The local database
For “Restore without DB”:
The cited page is best for a permanent DB recreate after restoring the job.
Import and export backup configurations can help to restore the job config.
Direct restore from backup files is an alternative without a job. It still needs
some critical information though, so make sure you keep that safely stored.
This method builds a partial temporary DB, so can be faster for one restore.
Restoring a bit at a time is probably faster if you make permanent DB in job.
