Hi, today i wanted to test if i can restore data from an backup and got the error in the title.
The first try was to recover data direct from the backup.
synologie-Clients
156,62 GB / 146 Versionen
Letzte erfolgreiche Wiederherstellung: heute um 13:12 Uhr (dauerte 00:11:24)
It was only one file and at the end i got the error. The file was only 0 bytes. The original is about 28kb.
In the process to choose the file to recover I got warnings. But when i press show, i don’t see the actual warning only older logs. I tried differnt backup versions and get the same error.
"RestoredFiles": 0,
"SizeOfRestoredFiles": 0,
"RestoredFolders": 0,
"RestoredSymlinks": 0,
"PatchedFiles": 0,
"DeletedFiles": 0,
"DeletedFolders": 0,
"DeletedSymlinks": 0,
"MainOperation": "Restore",
"RecreateDatabaseResults": null,
"ParsedResult": "Error",
"Version": "2.0.5.1 (2.0.5.1_beta_2020-01-18)",
"EndTime": "2023-03-22T16:18:29.0053609Z",
"BeginTime": "2023-03-22T16:10:56.0352006Z",
"Duration": "00:07:32.9701603",
"MessagesActualLength": 16,
"ErrorsActualLength": 2,
"2023-03-22 17:10:56 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: Die Operation Restore wurde gestartet",
"2023-03-22 17:10:56 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2023-03-22 17:11:03 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (1,22 KB)",
"2023-03-22 17:11:03 +01 - [Information-Duplicati.Library.Main.Database.LocalRestoreDatabase-SearchingBackup]: Searching backup 5 (14.03.2023 00:00:00) ...",
"2023-03-22 17:11:04 +01 - [Information-Duplicati.Library.Main.Operation.RestoreHandler-RemoteFileCount]: 1 remote files are required to restore",
"2023-03-22 17:11:04 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:12:38 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Retrying: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:12:48 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:14:05 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Retrying: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:14:15 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:15:34 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Retrying: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:15:44 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:17:02 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Retrying: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:17:12 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:18:28 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Failed: duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes (185,64 MB)",
"2023-03-22 17:18:29 +01 - [Information-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFailures]: Failed to restore 1 files, additionally the following files failed to download, which may be the cause:\r\nduplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes"
"Warnings": [],
"2023-03-22 17:18:29 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: \"duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes\", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data",
"2023-03-22 17:18:29 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFileFailed]: Failed to restore file: \"C:\\temp\\aktuell.docx\". File hash is 47DEQpj8HBSa+/TImW+5JCeuQeRkm5NMpJWZG3hSuFU=, expected hash is kXeZfVEQBUAJ92JDP6qP6lI0dNTmKM+Q58IB83IR/Es="
"RemoteCalls": 6,
"BytesUploaded": 0,
"BytesDownloaded": 0,
"FilesUploaded": 0,
"FilesDownloaded": 0,
"FilesDeleted": 0,
"RetryAttempts": 4,
"UnknownFileSize": 0,
"UnknownFileCount": 0,
"KnownFileCount": 1254,
"KnownFileSize": 168168213422,
"LastBackupDate": "2023-03-21T01:00:00+01:00",
"BackupListCount": 146,
"TotalQuotaSpace": 0,
"FreeQuotaSpace": 0,
"AssignedQuotaSpace": -1,
"Errors": null
I tried a recover from an other machine with manual giving the data and restored the whole folder with the file i got the error and every file could be recovery but only the one with problems couldn’t be recoverd with the same problem.
Here is the logfile:
Errors 9
2023-03-22 14:47:31 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-bb29ad1d3af664dd1a357d58474c31d5b.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 14:48:25 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-b0d30cc7903e2457e842fda18083cbace.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 14:54:59 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-bafbc4db1863a4b37867d99134e0eb2fb.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 15:08:27 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-b57e0ce8a4eef46a2a1400f718c658a3a.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 15:15:58 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-ba8068fb5e96043549ca86c8da071be99.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 15:28:43 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-bc4d49948603e4fa8a3b83fd35befb683.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 15:36:05 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-bb71f94388033410cbc839098baf041a2.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 15:47:32 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-bfc5507e4dc7f4ac18b6d55d21bf32123.dblock.zip.aes", message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Invalid password or corrupted data
2023-03-22 15:47:32 +01 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFileFailed]: Failed to restore file: "C:\temp\Ordner\Allgemein\aktuell.docx". File hash is 47DEQpj8HBSa+/TImW+5JCeuQeRkm5NMpJWZG3hSuFU=, expected hash is kXeZfVEQBUAJ92JDP6qP6lI0dNTmKM+Q58IB83IR/Es=
I use the latest stable version from duplicati and the backup is on a synology NAS with sftp. The backups run on a MS server 2016.
How can i repair the backup. I got no warnings and errors during the last backups. I tried file check but although got no errors.
