Restore Performance
I have a 4.6 TB backup that I wish to restore. The restore is taking a very long time and has had to be restarted several times.
The backup dataset is on a local SATA HDD. The restore destination is also on a local SATA HDD.
System is a workstation with good specs, 36 core Xeon with 256 GB of RAM, and a SATA SSD for primary storage. OS is Windows 10.
When running the restore I find that the system is mostly idling at around 20-30% CPU with intermittent peaks at 100%. What is most noteworthy is that the C drive (a good quality Samsung SSD, though on SATA III not NVMe) is completely and constantly pegged at 100% bandwidth and I suspect this is the bottle neck for the restore performance. Is the reason for this that the database is sitting on the C drive and is getting constantly hammered during the restore? If so, is there no way to put the database in RAM? If I was to attempt to do this myself (no code changes to Duplicati) can I create a RAM disk (say 10 GB) and then instruct Duplicati to store the rebuilt database on that RAM disk? Is there a Duplicati parameter to set the location of the rebuilt database?
The system is using about 50 GB of RAM for Duplicati, the rest is system cache. Can I tell Duplicati to use more RAM to try and speed things up?
Current restore performance is about 3 days to get 500 GB back, so I estimate roughly 27 days for the complete restore of 4.6 TB. Is this regarded as acceptable performance? Is this in any way “normal”?
Are there any pointers for improving restore performance?
PS: Duplicati version 2.2.0.3 - 2.2.0.3_stable_2026-01-06.
Happy to add to this.
Have restarted after setting up 64 GB RAM disk (Soft Perfect, SoftPerfect RAM Disk : high-performance RAM drive for Windows and macOS ) and moving/setting the Windows TEMP path to point to the RAM disk.
This has improved things in some areas, but not others. The main improvement was that recreating the database ran much faster, needing about 3-4 hours to rebuild the 11 GB database file, when previously it was more like 1/2 to 1 day (sorry for inexact metrics, I’m not exactly sitting here watching it constantly, there are other things to do).
Something negative that I am noticing at the moment is that the system seems to take more time to verify if an existing file is present (since this is a restart of a previous restore) than it would to just restore it afresh. Why is that? My guess is that the process ends up being the sum of collating the backup volumes to retrieve the blocks, as well as getting the blocks from the restore location, and the “worst case” penalty is that the blocks are already at the restore location so overall it runs slower. Or maybe I don’t know what it’s doing, sorry, it’s unclear.
The good news is that my local storage holding both the backup source and the restore destination, are now running at 100% bandwidth and the primary SSD is being left alone, as mentioned above.
To me, ideal restore performance would run at the maximum speed of the backup source and the restore destination, whichever is slower. In practice that will never happen due to the other things going on, and I’m well aware of what Duplicati has to do under the hood to make that happen. But this has been an interesting experience to observe what it does when CPU and RAM are not limiting factors. One thing I notice is that it is woefully inefficient with how the backup volumes are handled - they get copied to the temporary storage and then quickly deleted after, despite there being no space pressure on the temp folder.
All I can do now is let it run for a day or two and I’ll report back whether this has actually improved anything or not.
PPS: Lots of these showing up in the log:
“Block request for block 8737838 has been in flight for over 4719750 milliseconds. This may be a deadlock."
Next day update. The restore process stopped because the RAM disk ran out of space. I should have put more thought to it, since the bare minimum size is the DB (11 GB) plus the thread count by the volume size (36 x 1 GB) plus the scratch space for recreating the files, so at least enough space for the largest file in the backup set (in my case a handful of raw video files in the 10-15 GB size range). I started with 32 GB RAM disk, then extended it to 64 GB but you can see from the basic calculation above that it is not enough. So now I’m running it again with a 128 GB RAM disk and we’ll see how it goes.
As stated above, the entire point is to speed up the restore process. I had hoped to receive some feedback and pointers from others, but so far things are pretty quiet around here. Regardless, I’ll report back here how it goes in the hope that it is helpful to others.
5TB is a large backup, much less a restore. Whew! What immediately came to my mind was the the block size of the initial backup (Choosing sizes in Duplicati). I realize this doesn’t help in your current endeavor, but might be considered for future backups if such a complete restore again be required in a more timely matter. :thinking: :thinking: :thinking:
Thanks, I’ve been using Duplicati since 2019, pretty much as soon as Crashplan discontinued their backup client that made it easy to back up to your friends and family, and vice versa.
I’ve always made the Duplicati block size larger to keep the database size under some kind of control, and currently I use a 5 MB block size on all of my backups (smallest set is 2.5 TB, largest is this one at 4.6 TB). The database for the smaller one is about 4 GB and for this large one 11 GB. If I didn’t have an 8 TB SSD for primary storage I‘d probably increase the block size again and go for 10 or even 50 MB.
Something that’s been irking me is that I restored this backup about a year ago and it worked perfectly, fully restoring in about a week without any complaints or concerns. Unfortunately the drive I restored it to then went on to fail prematurely a few month later, and I have been too busy to restore it again until now. To save time last year, I simply cloned the backup set to a couple of drives and put them on the shelf. Now I need the files back in the active filesystem, so I’m attempting the restore and overall am just finding it to be much slower than I remember from last time. Perhaps some changes to the software have altered how the restore is performed?
One drawback of the release notices is the update after major release is partial.
Here’s what changed for all of the 2.2 Stable releases. One has to go digging…
Blog post: Cut restore times by 3.8x - A deep dive into our new restore flow
FWIW I saw almost no improvement on my old system. Forum has quite a few complaints about the management of temporary files within new cache design.
Restore methods speed comparison describes some improvements underway.
I don’t know if there are any useful stats kept by Duplicati to identify disk usage.
Windows users can watch the process with Sysinternals Process Monitor to see what sort of operations are hitting the drive. Database would probably be either database pathname or some suffixed version of it. SQL temporaries are etilqs.
Restored file paths should be obvious. Temporary files such as cache for restore probably begin with a dup- prefix, but really this is an area for developer assists.
Thank you for the contribution. For me, the most illuminating observation was that while a user may choose to restore from F drive to Z drive, the performance of the C drive (holding the temp folder) is a crucial part of the restore pathway. On systems with high performance CPUs with many cores, the path to the temp folder becomes the restriction. This is then confusing for users since they would not naturally expect their C drive, which to a casual user is not “involved” in the restore, to be rate limiting.
Hi @sgeklor !
I’m the author of the new restore flow that @ts678 mentioned.
That’s about 1.93 MB/s, which I’d say is pretty slow, especially when restoring from a local hard drive to another. My main guess as to why it’s so slow is that there is a problem with volume cache management in the current stable release (2.2.0.3) that leads to volumes being downloaded multiple times (see this discussion). The current default cache size value is 100 volumes (or dblock). E.g. the default being 50 MB volumes means a cache size of 5 GB. You can tune this using --restore-volume-cache-hint (e.g. --restore-volume-cache-hint=200GB to set the cache hint to 200 GB). When this cap is reached, volumes are evicted from the cache based on least recently used. However, since the volumes may still be in use, the actual disk space used by the cache may temporarily exceed the hint until the volumes are no longer in use and can be deleted. Note that volumes are also copied at least twice to the TEMP storage (1 for the download and 1 for the decryption).
Have you set --restore-volume-cache-hint setting? If not, with your volume size of 1 GB (it seems?) your cache hint should be 100 GB, which is why you’re running out of RAM disk space. 128 should be enough to run (100 volumes + 11 GB database) without running out of space (assuming nothing else is consuming that RAM disk space). You might still experience performance issues due to the re-downloading of the volumes when files are spread across volumes. The new restore flow is file-oriented and if a file is spread across multiple volumes, then all of those volumes need to be downloaded and decrypted before the file can be restored. For an unlucky (but is seemingly common) case, this leads to a volume being downloaded, decrypted, have one block extracted, and then evicted, thrashing the download.
One note on the volume size: larger volumes reduce the amount of parallelism that can be leveraged in the new restore flow by the volume downloaders, decryptors, and decompressors as there’s less volumes to work with and because a single volume (as it is now) cannot be processed in parallel. Secondly, larger volume sizes will require a larger cache size to be effective. Thirdly, if a volume is prematurely evicted from the cache, downloading it again will have a larger impact than with smaller volumes. The only real benefit that remains for larger volumes is that they may compress better (since compression is only applied within a single volume) and the overhead of metadata (e.g. zip headers) is reduced.
You can try the legacy restore by using the --restore-legacy=true option. The legacy restore is volume-oriented, holding only a single volume in memory at a time and only touching a volume once (download, decrypt, extract). The downside is that there’s not as much parallelism (only one volume is processed at a time), files are written in scattered fashion (since the blocks are scattered across volumes), and it has an additional verification step at the end of the restore, as the file hashes can only be verified once we know the entire file has been restored. The new restore flow knows exactly when each file is fully restored and can compute the file hash on the fly while it’s restoring the file.
This is expected behavior. The restore process first checks the local file system to determine which files are already present and match the expected size and timestamp. This is done to avoid unnecessary downloads of files that are already available locally. If a file is found to be missing or does not match the expected attributes, it will be marked for restoration, and the process will proceed to download the necessary volumes from the backup source. If you don’t want this behavior, you can set the options --restore-with-local-blocks=false to not use local blocks, and --overwrite=true to overwrite existing files. I can see that the new restore flow still checks the target files, which it could skip if these options are set, so I’ll look into that for a future update.
You mentioned that you have a large system, which could mean that the default concurrency parameters are far too large for a hard drive (which doesn’t like too much concurrent access), such as described in this post. The default is number of cores / 2 (same as the backup), so for your 36 cores that would be 18. The options are described in the blog post, but you might want to set --restore-file-processors (the number of processes that writes the target restore files) and --restore-volume-downloaders (the number of processes that download the volumes (or reads from the source drive in your case)) lower. 1 may not be enough to saturate the drive (as there’s some none-I/O processing that needs to be done), but you can experiment with different values to see what works best for your system. In the blog post I didn’t see too much of an performance improvement, but you may see something else.
This is a warning system in place to ensure that the network doesn’t stagnate due to a deadlock. It was introduced with the new restore flow as it’s using concurrent processes. So if you’re seeing system activity (be that CPU, network, or disk) related to Duplicati you should ignore the warning. If nothing’s happening, then it could indicate a deadlock, which should be reported. The threshold is set to 2 times the maximum round-trip time for a block request. If your disks are being overloaded by requests, then the round-trip time will increase, which will lead to the warnings being emitted.
Right, I can see how that can be confusing. The temp folder is used as a staging area for the volumes as they are downloaded, decrypted, and decompressed. I think that if we’re able to handle the volume cache more effectively (discussion) then this shouldn’t be as much of an issue. In the meantime, I’m not sure of how to convey this information better, as most (or at least myself whenever I use a new tool) don’t want to read the documentation to use the product and forcing a read is not ideal.
Not too much, but there is some if run with --log-level=Profiling and --internal-profiling=true (at least those provide information that’s parseable by me). I would like to build a more intuitive performance/profiling tool/UI to provide more insight to where and which bottlenecks reside. But that’s future work. There has also been added some cache metrics in this PR, but it’s yet to be included in a build.
Thank you for that very helpful and interesting reply.
I’m not sure if there is anything else I can do, other than wait. While I am tempted to restart and try some of your suggestions, the restart penalty (about a day for the software to rebuild the database and check the existing files and then actually start restoring new files) is rather off-putting.
If I change my mind I’ll let you know how I go.
What I will say is that it’s pretty clear that the task is IO bound and that CPU doesn’t really help. As you suggested, and my own observations confirm, having many powerful cores on hand is probably more of a hindrance than a help. Every time I look at the Duplicati temp working folder (in my case on a RAM drive, as explained in previous posts) I see dozens of files sitting there with 0 bytes waiting for their chance to get a backup volume from the store.
I do believe that getting the database into RAM has made a tremendous improvement to performance, but even if not, knowing I’m not burning up the SSD with many TB of transfers is good to know.
If this restore cannot complete in the next week, I’m definitely going to junk it and restart with the legacy restore algorithm.
After two days the restore had not yet processed 0.5 TB so I stopped it. As a reminder, the HDD holding the backup files was pegged at 100% the whole time, but very little was being written out to the restore location. I will also note that the web GUI would report all kinds of restore speed values, at times showing >800MB/s of restore performance, but on average 20-80 MB/s. Not sure if that’s because it’s not actually timing the restore pathway, which would be everything from: fetch backup volume → copy to temp →write restored block to destination. Tracking and timing that in detail would actually be a complex task with multiple time tracking stopwatches to track the parallel processes then a collator that would sum the partial bandwidths and produce a single value, all for the sake of a bandwidth report, so I don’t blame anyone for using a proxy value - it’s just in this case, under my circumstances, that proxy value was woefully incorrect and not at all helpful.
Last night I started again (formatted the restore location to start fresh) with only two modifications over the default behaviour:
  1. I have a RAM disk set up which hosts the Windows TEMP folder.
  2. I set the flag “--restore-legacy=true“
Since then, not only has it rebuilt the 11 GB database (as I commented above, the speed of this is very much improved by use of the RAM disk) it has already restore 0.5 TB, all within 12 hours of operation.
That is the performance that I remember from last time, and it is hoped that if I just leave it alone now it will restore in 3-5 days like before.
Based on my observations here, and those in the other threads, it does seem that the new restore algorithm may have some issues. I can certainly appreciate that the new algorithm may be faster when restoring part of a backup, or when other system resources are the limiting factor, but from my sample space of 1 the old algorithm is much faster for a full restore of a large backup on a high performance system. I hope this feedback can be taken on board to improve things in the future - even a basic branching operation could be helpful, where the program chooses the algorithm based on what it is being asked to do.
Thank you all, I’ll report here once the restore is complete (successfully or otherwise).
