Restore does not work
I’m using Duplicati (Windows 10 Pro) with GPG on WebDav remote with following additional settings, everything from WebGUI.
When I click Restore, it fails with following errors:
Warning:
2020-05-14 XX:XX:XX +XX - [Warning-Duplicati.Library.Compression.FileArchiveZip-BrokenCentralHeaderFallback]: Zip archive appears to have a broken Central Record Header, switching to stream mode
Errors:
2020-05-14 XX:XX:XX +XX - [Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: "duplicati-b3e544dc675b34b3aba31cef0b65a1e8d.dblock.zip.gpg", message:
2020-05-14 XX:XX:XX +02 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFileFailed]: The File "D:\TEST\TEST.txt" could not be found.
However, if I use Advanced > Commandline (from WebGUI) : restore > edit as text > Run “restore” command now … It works.
Advanced options:
–backup-name=TESTING
–dbpath=C:\Users\user\AppData\Local\Duplicati\QOFEEZQMGN.sqlite
–encryption-module=gpg
–compression-module=zip
–dblock-size=50mb
–keep-time=7D
–passphrase=mypassword
–gpg-encryption-switches=–cipher-algo AES256
–gpg-decryption-switches=–cipher-algo AES256
–disable-module=console-password-input
What happens on Commandline if you give a bad passphrase? I don’t run gpg, and don’t know whether that produces a decryption error, or an output file which is basically random data with a .zip extension.
One common problem in the GUI lately has been browsers and password savers autofilling bad spots…
Output from WebGUI Advanced > CommandLine
with correct password: working. File appears in “TEST” folder.
Restore started at 14.05.2020 XX:XX:XX
Checking remote backup ...
Listing remote folder ...
Checking existing target files ...
Downloading file (656 Bytes) ...
1 files need to be restored (2 Bytes)
Failed to apply metadata to file: "D:\TEST\", message: The process cannot be changed to the D: \ TEST file because it is used by another process. => The process cannot be changed to the "D: \ TEST" file because it is used by another process.
0 files need to be restored (0 Bytes)
Verifying restored files ...
Restored 1 (2 Bytes) files to original path
Duration of restore: 00:00:02
Did we help save your files? If so, please support Duplicati with a donation. We suggest 10€ for private use and 100€ for commercial use.
https://www.duplicati.com/donate/
Return code: 2
with incorrect password: not working. no file appears in “TEST” folder.
ErrorID: PassphraseChangeNotSupported
You have attempted to change a passphrase to an existing backup, which is not supported. Please configure a new clean backup if you want to change the passphrase.
Return code: 100
Well, I guess that idea got blocked. So do you ever have anything save passwords? I’d like to rule out:
I can’t restore from GUI with 2.0.5.1
and there are several others. In one GitHub issue, a Firefox private browsing window solved the issue, however the better long-term solution would probably be to not let any software autofill within Duplicati.
If that isn’t it, I have no other immediate theory on why your GUI Commandline works, but GUI doesn’t.
Chrome browser saved the password and that caused the issue! OMG.
To fix it, just delete all saved passwords from Chrome browser for Duplicati WebGUI.(http://localhost:8200/)
I also disabled uBlockOrigin for the page, just in case.
Thank You for the hint, @ts678 ! :slightly_smiling_face: :+1:
