how to restore backup on another desktop
First you need to install Duplicati. Then it depends if you have an export of your configuration or not.
If you don’t, select Restore → Direct restore from backup files (in the Web UI). You will be required to enter all relevant information (connection settings, encryption key, etc).
If you do, select Restore → Restore from configuration.
After that you’ll be able to select which files to restore.
