Running 2.0.5.1_beta_2020-01-18, on a backup set to Wasabi, I’m getting the following. Help?
System.AggregateException: One or more errors occurred. ---> System.AggregateException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock(String hash, Byte[] data, Int32 offset, Int32 size, CompressionHint hint)
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext()
---> (Inner Exception #0) System.AggregateException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
---> (Inner Exception #0) System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()<---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (400) Bad Request.
at System.Net.HttpWebRequest.BeginGetResponse(AsyncCallback callback, Object state)
at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl(Func`3 beginMethod, Func`2 endFunction, Action`1 endAction, Object state, TaskCreationOptions creationOptions)
at System.Net.WebRequest.<GetResponseAsync>b__78_1()
at System.Threading.Tasks.Task`1.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
at Amazon.Runtime.Internal.HttpRequest.<GetResponseAsync>d__16.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()
---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (400) Bad Request.
at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()<---
