Hello again. Sorry for the break in communication - had some troubles with my backup server. And you know: No server, no posts… ![]()
This is the logfile from the first day back online. Duplicati mentioned 170 warnings. Snapshots were set to “required”. Also the “write to logfile” option was turned on, but I receved an error: “logfile not accessable”. Will look into it.
Jan 30, 2019 8:29 PM: Result
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 6
ExaminedFiles: 53036
OpenedFiles: 18
AddedFiles: 12
SizeOfModifiedFiles: 3662924
SizeOfAddedFiles: 66524926
SizeOfExaminedFiles: 115256473687
SizeOfOpenedFiles: 70187850
NotProcessedFiles: 0
AddedFolders: 2
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults:
DeletedFileCount: 0
DownloadedFileCount: 0
UploadedFileCount: 0
DeletedFileSize: 0
DownloadedFileSize: 0
UploadedFileSize: 0
Dryrun: False
MainOperation: Compact
ParsedResult: Warning
Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28)
EndTime: 1/30/2019 8:27:07 PM (1548876427)
BeginTime: 1/30/2019 8:26:14 PM (1548876374)
Duration: 00:00:52.6502662
Messages: [
2019-01-30 20:23:04 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2019-01-30 20:24:33 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-01-30 20:24:38 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (5,42 KB),
2019-01-30 20:25:40 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b98fb25388e184e1a84f644f5d886233a.dblock.zip.gpg (313,94 KB),
2019-01-30 20:25:42 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b98fb25388e184e1a84f644f5d886233a.dblock.zip.gpg (313,94 KB),
Warnings: [
2019-01-30 20:23:43 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Users\XXX\Documents\YYY\Sharepoint\SharePoint\Templates - Documents\,
2019-01-30 20:23:43 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Users\XXX\Documents\YYY\Sharepoint\SharePoint\RD - Documents\,
2019-01-30 20:23:43 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: C:\Users\XXX\Documents\YYY\Sharepoint\SharePoint\QAQC - Documents\,
Errors: []
BackendStatistics:
RemoteCalls: 8
BytesUploaded: 5668474
BytesDownloaded: 57871908
FilesUploaded: 3
FilesDownloaded: 3
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 0
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 5553
KnownFileSize: 141034681193
LastBackupDate: 1/30/2019 8:23:04 PM (1548876184)
BackupListCount: 60
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
Messages: [
Warnings: [
Errors: []
DeleteResults:
DeletedSets: []
Dryrun: False
MainOperation: Delete
BeginTime: 1/30/2019 8:26:03 PM (1548876363)
Duration: 00:01:03.8985719
Messages: [
Warnings: [
Errors: []
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20190130T192304Z.dlist.zip.gpg
Value: [],
Key: duplicati-i09299b4398174a698aa76a4037e22cd4.dindex.zip.gpg
Value: [],
Key: duplicati-b6d999066c80e4f508459b2dc1ea8471a.dblock.zip.gpg
Value: []
EndTime: 1/30/2019 8:29:18 PM (1548876558)
BeginTime: 1/30/2019 8:27:11 PM (1548876431)
Duration: 00:02:06.4088496
Messages: [
Warnings: [
Errors: []
BeginTime: 1/30/2019 8:23:04 PM (1548876184)
Duration: 00:06:13.6303117
Messages: [
Warnings: [
Errors: []
Strange that this Sharepoint keeps popping up. Sharepoint synchronisation is enabled, but I haven’t moved any files for the past months.
Btw.: I use duplicati on the ubuntu computer of a family member. It uses the same transfer protocol (SFTP) to the same server. During a remote desktop session to the computer, I saw the following error popping up:
Unexpected result count: 0, expected 1
Seems familiar!? Maybe it has something to do with the protocol or the backup server? So I took a look at the servers logfile today, and I see plenty of these:
Jan 30 17:51:48 Jonas mountd[1935]: mount request from 192.168.1.14 for non existent path /Bicon
Jan 30 17:51:48 Jonas mountd[1935]: mount request denied from 192.168.1.14 for /Bicon
Jan 30 20:32:35 Jonas mountd[1935]: mount request from 192.168.1.14 for non existent path /XXX
Jan 30 20:32:35 Jonas mountd[1935]: mount request denied from 192.168.1.14 for /XXX
I am pretty sure it has something to do with duplicati, since the message stopped when duplicati was done doing backups. “Bicon” is a folder that I have on my computer - but I do not know why it should be causing problems.
