I run Duplicati on Windows 10 64 bit. I run it in service mode.
I turned on “Allow Remote Access” in Duplicati. When I went to Duplicati, it showed my last Backup was back in October, not the day before like I had setup.
October was when the Windows Fall Creators update nuked all my Duplicati settings (in service mode, Duplicati stores the settings in a folder that Windows wipes out on major updates). I managed to get everything running again at the time until now when I turned on “Allow Remote Access”
Duplicati started using settings stored in the folder that they were stored in before I started running in service mode. I don’t know why turning on remote access would do this, but that is the only Duplicati setting I have changed recently.
I stopped the service, and moved the files to the location that Duplicati is using now (C:\Windows\system32\config\systemprofile\AppData\Local\Duplicati\QSNQNCEYAT.sqlite). Upon restarting Duplicati, I tried to run a backup to Backblaze B2. But now I keep getting error messages along the lines of:
“Remote file referenced as duplicati-b998bd710bb6241bdbdb3d5ce80e939bb.dblock.zip.aes, but not found in list, registering a missing remote file”
I ran a database repair, that didn’t stop the errors from happening. I did a Recreate (delete and repair), and now I am seeing less errors, but I am still getting the same errors.
I’ve tried to turn off “Allow remote access (requires restart)”. But the setting doesn’t stick. I assumed the restart meant the service, so I saved the setting and restarted the service. When I go back into settings, Allow Remote Access is still checked. I tried again, this time restarting the computer instead of just the service. Again, the Allow Remote Access setting is still checked.
Anyone know how I can fix all of this?
