Release: 2.4.0.102 (Canary) 2026-09-25
2.4.0.102_canary_2026-09-25
New restore-test command
A new restore-test command restores a sample of files from a backup into a temporary folder and verifies them. The sample size, download budget, runtime and version can be controlled with the --restore-test-* options. For backups, the option --perform-restore-test-after runs the restore test automatically after a given amount of time.
Choosing a VSS provider
Windows snapshots can now use a specific VSS provider with --vss-provider-id=<guid>. The snapshot setup also detects a provider that does not expose mapped paths and cannot be used. If no provider is selected, it falls back to the Microsoft Software Shadow Copy provider.
Lower memory usage when deleting versions
Deleting, compacting, purging and repairing forced SQLite to build a large in-memory table holding all fileset entries being removed. The filesets are now removed one at a time, which bounds memory use to a single version. On a synthetic database with 100 versions and 300k files this was 16-20% faster with an 80% reduction in memory. The wasted space calculation was also rewritten and is roughly 9x faster on large databases.
Synchronization tool fixes
A number of problems in the remote synchronization tool were fixed, thanks @JamBalaya56562:
  • The backend managers received the wrong arguments, so a missing source folder was created and the empty listing deleted every file in the destination.
  • Folder entries reported by the destination are now ignored instead of failing the run.
  • Renames now use the backend’s own rename and content verification compares through temporary files, reducing peak memory from gigabytes to under 100 MB for large volumes.
  • Failed deletes and renames are now counted in the return code instead of reporting success.
  • A destination with mode interval or counting but no interval or count was only synchronized once. It now runs inline with a warning.
  • The --case-insensitive-remote option is now honoured, so a case-only rename no longer loses the file on case-insensitive destinations.
  • The primary sync database is now closed when the run ends, and the --sync-remote-state warning names values the option accepts.
Additionally, the tool no longer fails to copy folders on backends that report paths with a trailing separator.
Restore and backup no longer hang on failures
A restore that hit a volume it could not download, decrypt or decompress could wait forever instead of failing. All restore stages are now released when a volume cannot be produced. Similarly, stopping a backup while a backend call was stuck in a transfer that did not observe cancellation left the operation waiting; the backend manager now abandons the call and the operation returns as cancelled, thanks @JamBalaya56562.
Path redaction in reports
Additional checks prevent file paths from being included in logs and reports sent outside the system. The option --allow-paths-in-log-messages disables the redaction for environments where paths can be reported safely.
Selecting which operations send reports
The mail, HTTP, XMPP and Telegram reporting modules have a new option, such as --send-mail-operations, that selects which operations emit a report. The default is to report backups only, as before.
Command-line listing fixes
Several listing commands did not behave as documented, thanks @JamBalaya56562:
  • list-folder-contents now accepts a folder without a trailing separator and picks the latest version when no time or version is given.
  • search now searches sub-folders of the given folder.
  • list-file-versions and the V2 list-versions endpoint now return results and report correct timestamps.
  • purge and set-locks now stop when the given version or time matches no fileset instead of acting on every fileset.
Detailed list of changes
  • Fixed list-folder-contents returning nothing for a folder given without a trailing separator, thanks @JamBalaya56562
  • Added --vss-provider-id to choose a VSS provider, with a fallback to the Microsoft Software Shadow Copy provider when the selected one cannot be used
  • Added per-message ephemeral encryption keys and payload compression for console connections
  • Fixed search not searching the sub-folders of the given folder, thanks @JamBalaya56562
  • Fixed list-folder-contents failing with “Multiple filesets found” when no time or version is given, thanks @JamBalaya56562
  • Fixed a restore hanging forever when a volume cannot be downloaded, decrypted or decompressed, thanks @JamBalaya56562
  • Fixed a wrong missing key warning when using the default secret provider
  • Fixed an aborted operation waiting forever for a backend call that does not observe cancellation, thanks @JamBalaya56562
  • Fixed an exact time lookup returning every fileset when none matched, thanks @JamBalaya56562
  • Fixed a queued task being listed as running in the task queue, thanks @JamBalaya56562
  • Rewrote the wasted space calculation to be faster and use less memory
  • Fixed list-file-versions and the V2 list-versions endpoint returning no results and wrong timestamps, thanks @JamBalaya56562
  • Fixed a remote sync destination with mode interval or counting but no interval or count only synchronizing once, thanks @JamBalaya56562
  • Added path redaction checks for logs and reports and the --allow-paths-in-log-messages option
  • Added support for console status and error messages in Duplicati Backend so failure messages are less generic
  • Fixed most operations reporting 0% progress
  • Added a pluggable slot for license usage collection
  • Fixed the sync tool failing to copy folders on backends that report a trailing separator
  • Fixed purge and set-locks acting on every fileset when the given version or time matched none, thanks @JamBalaya56562
  • Hardened remote control callback requests and disabled redirects
  • Added login throttling to protect against brute-force attempts
  • Fixed Drime trash pagination validation and folder counts with trashed entries, thanks @tristanXme
  • Fixed a finished task reporting no outcome while it was still the current task, thanks @JamBalaya56562
  • Fixed the sync inventory folder listing being case-insensitive and unindexed, thanks @JamBalaya56562
  • Added --send-mail-operations, --send-http-operations, --send-xmpp-operations and --send-telegram-operations to choose which operations send reports
  • Added the restore-test command and the --perform-restore-test-after backup option
  • Fixed Google Workspace restore browsing being rejected due to a read-only scope request
  • Changed Google Workspace to emit a root folder like MS365
  • Fixed the SMB live test starting before Samba accepted connections, thanks @JamBalaya56562
  • Fixed the Windows shell icon overlay returning empty results and adjusted icon sizes
  • Fixed Google Workspace warnings and a lost license seat warning for suspended and archived users
  • Fixed the sync command ignoring --case-insensitive-remote, thanks @JamBalaya56562
  • Added a check that the VSS provider has mapped a usable path
  • Reduced memory usage when removing filesets in delete, cleanup, repair and purge
  • Reduced memory usage when deleting filesets during backup
  • Fixed the primary sync database never being disposed, thanks @JamBalaya56562
  • Fixed the sync tool returning success when deletes or renames failed, thanks @JamBalaya56562
  • Fixed the sync tool downloading volumes into memory for renames and verification, thanks @JamBalaya56562
  • Fixed the sync tool copying, deleting and verifying folder entries reported by the destination, thanks @JamBalaya56562
  • Fixed the sync tool passing the wrong arguments to its backends, causing an empty source to delete the destination, thanks @JamBalaya56562
  • Fixed the --sync-remote-state warning suggesting values the option rejects, thanks @JamBalaya56562
Updates to ngclient
  • Added a counter dialog for Google Workspace data
  • Added support for disabling chunking on S3 providers that do not support it
  • Fixed the restore file picker not handling a failed database repair, thanks @JamBalaya56562
  • Fixed a cancelled destination test not stopping the request, thanks @JamBalaya56562
  • Added WebModules storage, HTTP and destination test component tests, thanks @JamBalaya56562
