Release: 2.3.1.0 (Beta) 2026-07-28
2.3.1.0_beta_2026-07-28
This release is a Beta release intended to be used for testing to identify any issues before releasing the next stable version.
Breaking change: Locked-down data folder permissions
This release hardens security around the data folder and is a breaking change for some setups.
Duplicati now requires that the data folder has the exact expected permissions, or it will refuse to use it. Previously, Duplicati would silently lock down the folder if it was not already locked.
To opt out of the permission check, you need to either pass --allow-insecure-datafolder, set the environment variable DUPLICATI__ALLOW_INSECURE_DATAFOLDER=true, or place a file name insecure-permissions.txt in the installation folder.
Note that the previous method of placing insecure-permissions.txt in the data folder is no longer supported.
This change also applies to preload.json, such that it will only be loaded if the folder is trusted, or one of the opt-out methods are activated. Additionally, the previous trusted paths /usr/local/share/Duplicati/preload.json and C:\ProgramData\Duplicati\preload.json are no longer supported as they cannot be guaranteed to be locked down.
A preload.json inside the data folder is still supported, provided the folder passes the permission check.
The ConfigureTool has a new secure-datafolder command that can be used to force the correct permissions on the data folder.
For most users this should not cause any problems, as Duplicati has been locking down the folder already, but if you rely on lax folder permissions the setup needs to change. Some Docker setups may not be able to set the permissions and will need to apply DUPLICATI__ALLOW_INSECURE_DATAFOLDER=true in the image to run without the protections.
Sync copy mode
This release adds a often requested feature that enables simple copying of files from source to destination.
Where the regular backups are deduplicated, compressed, encrypted and versioned, the new sync mode will instead simply copy from source to destination.
The copy is currently a one-way sync, where the source is replicated on the destination. Files can be deleted on the destination during sync (use --sync-then-delete), but destination folders will not be deleted.
The option --sync-remote-state is by default set to UseRemoteState which will list the destination and figure out what to upload. The setting UseLocalState uses a local database, similar to how backups work, to keep track of known remote files, and reduce the amount of remote listings done. Finally, the BlindlyUpload setting will just copy everything as-is to the remote.
The sync jobs support remote sources, snapshots, and multiple destinations. If snapshots are enabled, the copy is done from the snapshot, ensuring reliable reads.
Configuration of such a sync job is done the same way as with backup, but using a toggle option in the first step of the UI. Note that backup and sync jobs are not compatible as they use very different storage logic, so it is not possible to change the job mode after creating a job.
CLI mode also supports sync.
Improved Windows installer
This change brings a major update to the Windows installers, which now integrates the ability to run as a service, as well as generate and use TLS (https). The service feature has been present for a while in the WindowsService.exe tool and the TLS certificates were added as part of the Duplicati.CommandLine.ConfigureTool.exe. With this update these things are now integrated into the installer, and exposed as simple checkboxes to toggle the features. Installing the service from a regular user account, will also auto-generate a secure password and configure the TrayIcon to connect to the service (only for the current user).
If you have installed the service manually, do not activate the new checkbox as it only works if there is no pre-existing service. The installer-driven service does not support commandline arguments directly, but instead prefers preload.json files to configure it. The MSI supports the property INSTALL_PRELOAD=true which will cause it to pick up a preload.json file from the same folder the MSI is located in.
The Windows service is now also configured as delay-start service to avoid startup issues on boot.
Live reporting module
This release adds a new live-reporting module that sends the current progress of backups to a user-specified URL. The intention is that this can be used for dashboards that want to show the current progress for backups. By default, the module is not configured and has no impact.
PAR2 parity / error-correction for remote volumes
This release adds a pluggable parity module that produces error-correction data for remote data volumes, so they can be repaired after bit-rot or corruption on the backend, thanks @JamBalaya56562.
To enable this, ensure that par2 is installed on the machine and set --parity-module=par2. Setting this will cause additional .par2 files to be uploaded.
Store configuration with backup
This release revives the store-task-config option and makes it enabled by default for encrypted backups. The backup configuration is stored with the backup data, making it easier to restore a configuration later.
For unencrypted backups, no secrets are stored by default. The behavior can be customized with options to store none, self, or all configurations, with or without secrets. The UI has been updated to allow restoring from the destination config. If multiple configurations are found, the user can select one or more backup configurations to restore.
MS365 subsites and shared mailboxes
This release improves the Microsoft 365 backup support with two additions.
Support for backing up SharePoint subsites has been added, making it possible
to include sub-sites beneath a site collection in a backup.
The handling of shared mailboxes has also been improved, with better detection
and enumeration of shared mailboxes within a tenant.
The license counter now excludes shared mailboxes without a license, and supports
top-level filtering of users/sites/groups based on classification.
Full disk backup support (Windows, Linux, MacOS)
This release extends the full disk backup feature to support Linux and MacOS.
The Linux support allows backup and restore of entire disks on Linux, including partition tables. The MacOS support adds basic backup and restore of entire disks, including partition tables.
Like the Office 365 / Google Workspace backup features, this is a proprietary module (source available) that requires a license to use in production.
Full disk backup requires administrative privileges to access the disk directly.
Full disk restore requires administrative privileges and requires that the disk is unmounted and not write-protected.
Read-only testing of backends
Backends now support read-only context-aware testing, which allows testing connections safely without risking unintended changes to the storage. The read-only testing is applied when testing a restore destination or a remote source, such that no files are attempted written to the remote storage.
New backends
Added support for Drime Cloud as a new storage backend.
Added a new backend for the Spanish provider Movistar, thanks @redmars27. The backend is marked as “untested” as it can only be used (and tested) by Movistar customers.
Deprecated backends
The previous “SharePoint” and “OneDrive for Business” backends have been marked as deprecated, as Microsoft shut down the API they were calling. The migration step is to use the “SharePoint v2” backend (renamed to just “SharePoint” in this version) which uses the Microsoft Graph API.
FAT32 and NTFS support for full disk backup
Added FAT32 and NTFS file system support for the full disk backup feature, including boot sector parser, table reader, streams, and directory walker. This features makes it more efficient to do full-disk backups.
To enable this feature, add the advanced option --diskimage-filesystem-parsed=true and the backups will attempt to parse the disk, and if it is one of the supported formats, it will only read the relevant sectors.
Remote synchronization improvements
Integrated remote synchronization feature (aka 3-2-1 backups) from a separate module into the Main library for better integration, with improved error handling, progress tracking, and reliability.
Added destination space quota checks to the remote synchronization runner, helping prevent failures due to insufficient destination space.
An option to disable quota checks (quota-disable) has also been added for scenarios where quota information is not available or reliable.
Duplicati Storage
This release also includes the Duplicati Storage which is integrated with the Duplicati console. Once a machine is connected to the console it can use the accounts storage allocations with zero configuration required.
SharpAESCrypt v3
Updated the SharpAESCrypt encryption library to support “AES Crypt Stream Format v3”, which has a number of improvements over the v2 format.
For this release, the default written format remains v2, but we encourage you to set the environment variable DUPLICATI__AES_VERSION=3 to test the new format.
Note: if you set this version to 3, the new remote volumes cannot be read by Duplicati versions older than (2.3.0.101).
Support for MacOS ACLs
This release adds support for reading MacOS attributes and ACL strings during backup, and restoring them when permission restores are selected.
Support for Windows Alternate Data Streams
This release implements support for reading and writing alternate data streams (ADS) on Windows. This feature is disabled by default and can be enabled with the advanced option --enable-ads-backup. If ADS content is found in the source, this is restored by default but can be disabled with --disable-ads-restore.
Fixed MSSQL backups
Since 2.1 the MSSQL backups would produce errors if attempting to back up an MSSQL server that was running as the default instance, but would work with a named instance. This release fixes the issue and now handles both default- and named instances.
Improved missing source handling
The default behavior when sources are missing has changed. Previously, a missing source would abort the backup. Now, a missing source will only trigger a warning unless the option --abort-if-source-missing is set. The option --allow-missing-source can still be used to suppress warnings entirely. If no sources are found at all, the backup will still abort.
Relative database paths
Database paths are now stored relative to the data folder by default. This makes it simpler to move the data folder as the paths are not stored in full. Existing backups retain their full paths, but manually updating a database path will make it relative if it is within the data folder.
Updated LibSecret support for KDE
The LibSecret support has been updated to work correctly on KDE Plasma 5+6. The default collection alias is now properly resolved, fixing issues where a new collection named default would be created incorrectly.
Improved source tree
To make it easier to see what data is included, the source tree will now show the content of remote sources, including Microsoft 365 tenants, Google workspace subscriptions and full-disk content.
Improved filter accuracy in the UI
The filter evaluation will now be performed server-side if the filters are not “simple filters”. When a non-trivial filter is in the list, the C# code will be asked to evaluate the list and produces the filtered results which are then displayed. This increases the correctness of the displayed filter state because the same code is now used for both display and actual backup operations.
Resolve shortcut entries
The helper entries, like “My Documents” are now shown in all picker situations and resolve to the full path. This makes it possible to use these shortcuts to pick things like log-file location or SSH keyfiles, without having to traverse the full tree to find the locations.
Browse remote destinations
The destination configuration has been updated to include a browse button for finding the remote destination path. Once the connection details are in place, the browse button can be used to navigate the remote file system and select the desired destination folder. This works both for configuring a backup and for picking the restore location.
New welcome page and start
The UI will now show a welcome page showing how to connect to the console with an option to continue without.
This can be suppressed with the option --webservice-suppress-welcome-page=true or environment variable DUPLICATI__SUPPRESS_WELCOME_PAGE=true.
If the connection is made from the TrayIcon, the initial dialog asking to set a password is no longer shown, as the intention is to use the TrayIcon to connect.
It is still possible to change the password from the Settings page if needed.
Crash dialog
Added a crash dialog window that appears when the application encounters an unhandled exception.
Thanks to contributors
This release is once again a collaboration effort from the Duplicati community. Thanks to the many contributors who reports issues, test new releases, requests features, write documentation, maintain translations, and contribute to the codebase.
I have installed this new beta in a couple of locations. So far, most things appear to be working as expected.
I still have the problems I have mentioned in this post for the release of 2.3.0.4 stable.
Also, when using multiple destinations I noticed another strange issue. Prior to Duplicati including multi-destination backups I had several endpoints where I had implemented them manually via rclone to copy the backup files to an alternate site.
I tried to shift this functionality into Duplicati by adding the second destination to the backup job in Duplicati. It “worked” but it deleted everything in the second destination and then re-uploaded it all, despite the fact that it was 99% the same files.
Hi, when you write the Stable release notes, could you maybe move the “for most users” paragraph to the start of the Breaking Change section, so that ordinary home users don’t have to struggle with all that text?
And maybe please could you clarify this phrase “data folder”?
Do you mean the destination folder that holds the Backups? Or is “the data folder” part of the Duplicati installation (as the filepaths a few paragraphs later suggest)?
I am a home user of Duplicati so I only visit here occasionally and I don’t really stay-to-date with all the jargon.
Thank you for your continued development work.
I have made a note of it; it seems there are some quirks related to the multi-destination feature.
The plan for the next stable release (2.5) is to integrate it more into the main flow, and re-use the new sync code to handle the multiple destinations instead of the current approach.
Good point. I will do my best to fix that.
