I ran the repair and now I get this
"2026-07-21 10:04:38 +02 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Repair has started",
"2026-07-21 10:04:38 +02 - [Information-Duplicati.Library.Main.Operation.RepairHandler-RenamingDatabase]: Renaming existing db from C:\\ProgramData\\Duplicati\\ICXFGPFETH.sqlite to C:\\ProgramData\\Duplicati\\ICXFGPFETH.backup",
"2026-07-21 10:04:38 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2026-07-21 10:04:38 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (3.609 KiB)",
"2026-07-21 10:04:38 +02 - [Information-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-RebuildStarted]: Rebuild database started, downloading 32 filelists",
"2026-07-21 10:04:38 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20240614T040021Z.dlist.zip.aes (3.520 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-20240614T040021Z.dlist.zip.aes (3.520 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20240717T040010Z.dlist.zip.aes (3.723 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Compression.ZipCompression.FileArchiveZip-CompressionReadErrorFallback]: Failed to open file with built-in ZIP archive, falling back to SharpCompress\r\nInvalidDataException: The archive entry was compressed using LZMA and is not supported.",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-20240717T040010Z.dlist.zip.aes (3.723 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20240818T040007Z.dlist.zip.aes (3.350 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-20240818T040007Z.dlist.zip.aes (3.350 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20240924T120341Z.dlist.zip.aes (3.496 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-20240924T120341Z.dlist.zip.aes (3.496 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20241101T050001Z.dlist.zip.aes (3.111 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-20241101T050001Z.dlist.zip.aes (3.111 MiB)",
"2026-07-21 10:04:39 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20241208T020001Z.dlist.zip.aes (4.048 MiB)"
Some of the warnings:
"Warnings": [
"2026-07-21 10:04:39 +02 - [Warning-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-FileProcessingFailed]: Failed to process file: duplicati-20240614T040021Z.dlist.zip.aes\r\nInvalidManifestException: Invalid manifest detected, the field Blocksize has value 102400 but the value 1048576 was expected. This could be a configuration issue, or be caused by mixing files from different backups.",
"2026-07-21 10:04:39 +02 - [Warning-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-FileProcessingFailed]: Failed to process file: duplicati-20240717T040010Z.dlist.zip.aes\r\nInvalidManifestException: Invalid manifest detected, the field Blocksize has value 102400 but the value 1048576 was expected. This could be a configuration issue, or be caused by mixing files from different backups.",
"2026-07-21 10:04:39 +02 - [Warning-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-FileProcessingFailed]: Failed to process file: duplicati-20240818T040007Z.dlist.zip.aes\r\nInvalidManifestException: Invalid manifest detected, the field Blocksize has value 102400 but the value 1048576 was expected. This could be a configuration issue, or be caused by mixing files from different backups.",
Some of the errors:
"2026-07-21 10:04:41 +02 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-IndexFileProcessingFailed]: Failed to process index file: duplicati-i0001ad36ac1448f4a262cbbe4c40c5ec.dindex.zip.aes\r\nInvalidManifestException: Invalid manifest detected, the field Blocksize has value 102400 but the value 1048576 was expected. This could be a configuration issue, or be caused by mixing files from different backups.",
"2026-07-21 10:04:42 +02 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-IndexFileProcessingFailed]: Failed to process index file: duplicati-i005513f58ae34d9b9522cf860519b728.dindex.zip.aes\r\nInvalidManifestException: Invalid manifest detected, the field Blocksize has value 102400 but the value 1048576 was expected. This could be a configuration issue, or be caused by mixing files from different backups.",
"2026-07-21 10:04:42 +02 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-IndexFileProcessingFailed]: Failed to process index file: duplicati-i006aef4be1d04371842ddb5b3c9f2b5c.dindex.zip.aes\r\nInvalidManifestException: Invalid manifest detected, the field Blocksize has value 102400 but the value 1048576 was expected. This could be a configuration issue, or be caused by mixing files from different backups.",
"2026-07-21 10:04:42 +02 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-IndexFileProcessingFailed]: Failed to process index file: duplicati-i007e67e7f2ca4f62a91f8adb0d46e5ee.dindex.zip.aes\r\nInvalidManifestException: Invalid manifest detected, the field Blocksize has value 102400 but the value 1048576 was expected. This could be a configuration issue, or be caused by mixing files from different backups.",
