2.2.0.105_canary_2026-02-20
This canary release is intended to be the base for the next beta/stable release.
Changes in this version
Database schema updates
This version updates the Server database schema to version 11 (was 9 in 2.2.0.104).
These changes add the new remote destination repository table, and a table for tracking multiple backup destinations.
Updates are applied automatically, and if you need to downgrade, the database tool can perform downgrades.
Downgrades will wipe the new backup destinations and the backup destination repository, but otherwise does not cause data loss.
Multiple backup destinations
This version adds support for configuring multiple destinations for a single backup job.
This allows you to backup to multiple locations simultaneously, such as a local drive and a cloud storage provider.
With multiple destinations, you can now configure a complete 3-2-1 backup strategy in a single job.
After each completed backup, Duplicati will ensure that data is available on all destinations.
A 3-2-1 backup strategy is where you have 3 copies of your data, 2 of which are on different media, and 1 of which is offsite/immutable.
Windows folder status indicator
Thanks to @AndyBodnar, this version adds a Windows shell extension that shows the backup status of folders with icon overlays.
The feature is disabled by default but can be enabled with the option --enable-folder-status-service on either Server or TrayIcon.
Once the feature is enabled, you can run the RegisterFolderStatusExtension.ps1 script to register the extension, and you can then see the backup status of folders in Windows Explorer.
Google Workspace backup
This version adds support for backing up Google Workspace, including Gmail, Google Drive, Contacts, Calendar, and Chat.
Like the Office 365 backup feature, this is a proprietary module (source available) that requires a license to use in production.
Without a license, testing is possible with up to 5 users.
If you prefer a clean OSI-approved installation, you can prevent proprietary modules from loading by setting the environment variable DUPLICATI_DISABLE_PROPRIETARY_MODULES=1 or simply delete the files named Duplicati.Proprietary.* from your installation.
Full disk backup
This version adds simple support for backup and restore of entire disks, including the MBR/GPT partition table.
In this initial version, only Windows is supported, the backup is accessing the disk directly (no VSS).
We are working on adding support for Linux and macOS, as well as VSS support for Windows.
Like the Office 365 / Google Workspace backup features, this is a proprietary module (source available).
Full disk backup requires administrative privileges to access the disk directly.
Full disk restore requires administrative privileges and requires that the disk is unmounted and not write-protected.
Bugfixes and improvements
- Fixed S3 endpoint port preservation and path validation, thanks @aureliandevel
- Added connection string repository for simpler management of re-used backend connections
Detailed list of changes:
- Added support for full disk backup and restore on Windows
- Fixed incorrect commandline argument names in Agent
- Added support for assigning license from console
- Added Windows folder icon overlay for backup status, thanks @AndyBodnar
- Fixed compile errors after merges
- Added Google Workspace backup support
- Added temp disk space check endpoint
- Added support for multiple backup destinations
- Updated translations
- Fixed race condition with index file uploads during backup
- Added latest translations
- Updated translations from Transifex
- Rolled back supplementary groups change
- Fixed S3 host port preservation and path validation, thanks @aureliandevel
- Fixed nullable warnings
- Fixed large volume inputs handling
- Fixed RPM spec ownership calculation
- Fixed scheme detection on short paths
ngclient changes:
Features
- Added support for picking disks for backup (if supported by the backend)
- Added support for Google Workspace
- Added support for saving multiple destinations
- Added destination page
- Added const to toggle auto-save of destinations
- Added missing dropdown options for filters
Bug Fixes
- Fixed issue with crashes in Chrome when showing tooltips
- Fixed issue with “loader” buttons shrinking visually
- Fixed advanced options not possible with UNC paths
- Fixed include filters converting to paths
- Fixed multi-line small screen styling of menu
- Fixed non-existent icons
Improvements
- Improved mobile display (responsive layout)
- Improved status content
- Improved status file text
- Updated localizations, thansk to all translators
- Updated status and destinations
- Automatically open warnings/errors on the logs page
