2.1.2.2_beta_2025-10-10
This release is a beta release inteded to be used for testing.
If no major issue are found with this release, it will be used to create a new stable release.
About this release
This release is primarily a bugfix release from the previous beta and fixes a few minor issues discovered during the testing period.
Database version upgrade
No database version upgrades in this version, but the beta releases updates the local database to v17 and the settings database to v9.
The database tool can downgrade to previous versions.
New since last beta
- Fixed an issue with rebuilt database having null values for hashes
- Fixed an issue with non-US locales using different characters for the negative number symbol
- Updated UI to latest version to fix tooltip issues
Summary of large changes since last stable
- New user interface
- New datafolder default location for Administrator/root
- New backends pCloud, Filen and Filejump.
- New backend for SMB to avoid mounting shares
- Removed Sia backend and marked Mega as deprecated
- Common http options are now applied to backends, and timeout options are renamed
- Installer packages are now signed by Duplicati Inc
- Remote source support for S3, SSH and SMB
- Database is upgraded to v17 for local db, and v9 for settings database
- Database upgrade/downgrade tool is provided
- New file and folder enumeration logic
- Timeouts logic on all backend operations
- Improved database validation and repair logic
- ServerUtil can output JSON for script integration
- Improved support for having Duplicati behind a proxy
- Updated throttle logic, all streams share the throttle
- Improved repair logic
- VSS is automatically on if running on Windows with sufficient privileges
- Improved backend test function
- Ability to suppress warnings
- Support for remotely managed backup configs
- Added support for Google IAM
