Release: 2.1.1.104 (Canary) 2025-10-03
2.1.1.104_canary_2025-10-03
Changes in this versions
This version is a bugfix release for some issues discovered with the previous canary build.
Detailed list of changes:
  • Fixed unmasking password from commandline UI
  • Fixed ngax loosing all customer destination editors
  • Fixed a wrong lookup for file size during restore file listing that caused slowdowns
  • Added alerts on login/signin pages that JavaScript is required
  • Updated Storj library uplink.NET to 2.14.3598 for fixing Linux crashes
  • Fixed an issue with restore flow that could deadlock an block restores
ngclient changes:
  • Updated localizations, thanks to all translators
  • Added support for masked passwords when testing a connection
  • Fixed some buttons not being styled correctly
The “missing files” bug with the b2 backend is still present in 2.1.1.104_canary_2025-10-03. Details/discussion at Missing files on remote.
