Release: 2.1.0.3 (Beta) 2025-01-22
2.1.0.3_beta_2025-01-22
This release is a beta release, considered to be stable for general use.
This release is expected to progress to a stable release if no major blockers are found.
Unlike 2.0.8.1 and earlier Duplicati now runs on .NET8.
The builds are self-contained so Mono or .NET installations are not required to install.
Automatic updating to this version is not supported.
Important changes from 2.0.8.1
  • Updated to .NET8 with OS specific builds
  • Using Kestrel as the API/UI server
  • Mandatory password and new authentication scheme for server
  • Settings database version updated to v8
  • Backup database updated to v13
New tool to manage a running server
Due to incompatibility with duplicati_client a new tool is included, named Duplicati.CommandLine.ServerUtil.exe/duplicati-server-util.
This update builds on 2.1.0.2 and fixes a number of issues that were reported and fixed with the help of the incredible Duplicati community.
Summary of changes from 2.1.0.2
  • WebSocket path is proxy aware
  • Removed most of the noisy log messages
  • Fixed some issues with QuotaInfo on the file-based backend
  • Multiple fixes to the FTP backend
  • Agent can now register-then-exit and retain password
  • Updated SSH.NET to fix an issue with missing HMAC algorithm
  • Changed docs link to point to new docs site
  • Added read-write timeout to most backends
  • Added option to issue a “forever token” for use in authenticated environments
  • Updated MacOS launchAgents in .pkg files
  • Preload configuration now supports the data folder
  • Fixed bugreport download
  • Fixed shutdown crashes in TrayIcon
  • Updated translations, thanks to the translation community!
  • Fixed TrayIcon disconnecting after 15 minutes
  • Removed the Captcha for deleting remote files
  • Added help links to login pages to explain how to get access
  • Support for self-signed certificates when sending http reports
  • Extended ServerUtil with a status command and option to wait for backups to complete
  • Fixed a bug preventing database recreate in special cases
  • Prevent optimize calls after calling vacuum on the SQLite database
  • Added a warning if the volume size is excessive
  • Fixed a logic test for AWS S3 permissions
what is changed from 2.1.0.2?
Edit: sorry.
Please see the bottom section of the release note for a summary of changes from 2.1.0.2.
