2.1.0.123_canary_2025-07-09
This version is nearly identical to 2.1.0.121 which has a startup crash.
This version is nearly identical to 2.1.0.122 which has an issue with detached TrayIcon.
Major changes in this version
This version introduces a new SQLite library, a new VSS provider, and some minor bugfixes.
SQLite update
This version has changed the SQLite library from the previous System.Data.SQLite library to using Microsoft.Data.Sqlite.
This update was quite invasive, as the new SQLite library does not support positional arguments in SQL queries, which was used extensively in the Duplicati codebase.
With the update we see measurable speedups across all queries, and we are producing an article that describes our findings.
The update also bumps the SQLite library to use the latest available version and makes all SQLite queries async and cancelable, making the stop commands more responsive.
New VSS provider supprt
The AlphaVSS library that is used for creating VSS snapshots is no longer being maintained.
This version now defaults to using the Vanara API layer to call the Windows VSS API and create snapshots.
Like before, this still requires the VC++ Redist to be installed.
For now, it is still possible to use AlphaVSS by setting --snapshot-provider=AlphaVSS.
Note that neither works on ARM64 as Windows is lacking libraries and tools for native ARM64 snapshots, only --snapshot-provider=WMIC works on ARM64.
Bugfixing for ngclient
A number of reported compatibility issues with ngax has been fixed in this version.
Detailed list of changes:
- Commandline UI expands environment variables
- The
file://backend is no longer throttle exempt by default - Fixed issue with TrayIcon not outputting help text in all cases
- No longer retains SeBackupPrivilege after testing for permissions
- Refresh token lifetime can now be configured
- Fixed multiple issues with kill signals not stopping the process
- Secret provider now correctly applied for all TrayIcon arguments
- Updated SQLite library to use
Microsoft.Data.Sqlitepackages instead - Default VSS provider is now Vanara
- Hide options that are not supported on the current OS
- Fixed backup schedule order after multiple missed backups
- Fixed an issue with Google Drive backend not creating folders
- Updated all localization, thanks to all translators
Updated in 2.1.0.122
- Fixed numeric Id sorting
- Updated texts for disabling index recreate
- Fixed a crash on startup in 2.1.0.121
- Fixed an issue with restore listing speed
Updated in 2.1.0.123
- Fixed a crash with detached TrayIcon
- Fixed an error when creating a bugreport database
- Added faster status updates in UI
- Fixed a parsing issue with the remote sync tool
- Fixed an issue where some operations would report success even if they failed
Ngclient changes:
- Fixed issue with
--option prefixes not being matched - Updated all localization, thanks to all translators
- Fixed issue with en-GB not using 24h time format
- Fixed issue with editor for GCS not having a path field
- Fixed issue with editor for B2 introducing extra
/characters - Fixed supporting -s postfix for backends for backwards compatibility
- Fixed case-insensitive support for boolean and enumeration options
- Custom arguments is now a two-line input
- Fixed showing destinations with no custom UI
- Fixed an issue with decoding URL artefacts in paths
- Change storage of preferences (this will reset som settings like sort order and dark-mode)
- Added option to not store a cookie token after login
- Added a button to create folders when restoring and picking destination
- Fixed deprecating CIFS and using SMB instead
- Added Next Scheduled Run to backup list
- Added a “Operation is starting …” message to not show “Starting backup …”
- Moved bugreport to the database page
- Fixed wrong editor mapping for COS and AliyunOSS
- Fixed an issue where a custom text for a dropdown would be lost on edit
- Fixed an issue with direct restore that would prevent restore from starting
- Added advanced settings for the direct restore flow
- Added an “Edit as text” option for advanced options
