2.1.0.114_canary_2025-04-14
This version is the same as 2.1.0.113 but rebuilt to fix a build-time issue.
Major changes in this version
The ServerUtil tool can now ouput JSON instead of regular text.
Support for Zip64 is now always enabled, so manual data extraction requires a Zip64 enabled tool.
Added support for creating pre-authenticated headers to better support proxy setups.
Improved handling of duplicated blocks, both on compact and on backup.
Added support for Filen and Filejump storage destinations.
Potentially breaking changes (from 2.1.0.109)
- Location of data folder has changed in some cases, refer to previous release for details
- Permissions are now applied to the data folder, refer to previous release for details
- New user interface,
ngclientis the default; there is a button to switch between the two
Detailed list of changes:
- Improved build process and added checks for missing and outdated libraries
- Improved anti-sleep on Windows
- Added option to emit machine-readable JSON from
ServerUtil/duplicati-server-util - Fixed issue with Mega backend not authenticating
- Added back missing options to MSGraph based backends
- Improved Zip64 support (always on)
- Prevent crashes when unable to set permissions on data folder or database
- Added
Filen.iobackend - Fixed some delivery failures to Telegram
- Prevent setting permissions on data folder from ServerUtil
- Added support for pre-authenticated headers in selfhosted (proxy) setups
- Stop early if restoring a backup and no passphrase is supplied
- Removed a warning show when using relative restore version time
- Removed positional arguments from SQL queries
- Improved number of blocks that can be discarded during compact
- Improved storage re-use if files are added/removed/added
- Fixed a case where connections were not closed after use
- Updated Wasabi S3 endpoints
- Fixed locale-sensitive parsing bug for fr-CA
- Added
rcloneto Docker images, thanks @wjansenw - Added Filejump backend
- Fixed some error flows during restore with missing data
Ngclient changes:
- Fixed external links opening in new window
- Show error messages when testing connection
- Fixed bug with not setting server interface
- Added a tab to show crash log data
- Added sorting to list of backups
- Added Filen backend support
- Fixed removing backup when deleting
- Fixed dropping config file for restore
- Error messages can be dismissed
- Added support for date-time options
- Added live-logs and improved logs area
- Added controls for entering timespans
- Improved status bar and loading messages
- Fixed cases of white start screen
- Fixed issues with settings page not updating
- Fixed issue with loading exported config with path-encoded url
- Fixed File browser starting in broken state if path is missing
- Added support for Filejump backend
- Fixed issues with parsing dblock-size
- Added support for retention settings
- Fixed issues with timespans on edits
