Release: 2.1.0.112 (Canary) 2025-03-26
2.1.0.112_canary_2025-03-26
Major changes in this version
  • Updated backends
    The major change in this version is the addition of timeouts to every backend.
    This has the potential to affect each backend individually.
  • Improved validation
    Further increased the checks made to validate that the database is consistent, and added new features to the repair operation to assist in recovering.
    Certain problems are now checked before and after a backup, in an attempt to better close in on the conditions that create these situations.
  • Updates to ngclient
    Updates to reconnect logic and locale support.
Potentially breaking changes (from 2.1.0.109)
  • Location of data folder has changed in some cases, refer to previous release for details
  • Permissions are now applied to the data folder, refer to previous release for details
  • New user interface, ngclient is the default; there is a button to switch between the two
Detailed list of changes:
  • Added retries for sending HTTP-based reports
  • Added warning icon back to TrayIcon
  • Fixed a check that prevented repairs in timezones that are have a negative UTC offset
  • Rewrote a number of SQL queries to avoid localization of SQL strings
  • Added guards against faulty startup delays
  • Updated all backends to use same parsing logic for authentication options
  • Updated all backends to support timeouts
  • Fixed a bug where databases would be created with strict permissions, even if opting out
  • Updated SQLite loading to always set custom pragmas
  • Updated SQLite loading to support custom SQLITE_TMPDIR environment variable
  • Removed unwanted data in report JSON output
  • Added support for deleting empty index files on repair
  • Improved handling of stop “errors”
  • Updated box.com backend to use HttpClient
  • Added option to inject custom parameters into reports
  • Improved error message on manifest version mismatches
  • Removed a warning when attempting to pick a restore date with a negative prefix
  • Support for large form-encoded HTTP reports
  • Fixed an issue where the URL parser would return different results for similar inputs (for the file:// input)
  • Handling backspace on console password input
  • Added guard against fileset errors in the database
  • Added support for rebuilding filesets from remote data on repair
  • TrayIcon can now start in a disconnected state, and keep probing for a connection
  • Added current update channel to reports
  • Added automatic zip64 usage for large bugreports
  • Added support for showing the crashlog in the UI
  • Fixed an issue with some dates causing problems in the timezone aware calculations
  • Added support for sorting the list of backups in the UI
  • Fixed an issue with restoring timestamps and metadata on folders
Is that it? Detailed list of changes has none. Job Submit still fails on bad retention.
I took screenshot as soon as final screen arrived because it seemed a bit strange.
If there’s a path to getting Submit to work, the formula would help testing progress.
Not sure if there’s anything changed though.
Tried an Import from file in ngclient of an existing job. On Destination screen:
So “Path in the bucket” is showing percent-encoded spaces instead of spaces.
The forward slash at the start also shouldn’t be there.
On Source Data screen, none of my sources are in the tree view, and clicking various things around there doesn’t seem to be willing to show or allow adding.
On Options screen, I do see two of my many options, but all the rest are gone.
Decided to try a Submit anyway, and to my surprise it worked and this job and previous fail showed up on the screen. Switch to ngax to see if result looks OK:
Bad leading slash went away, bad percent encoding stays.
Application ID and Application Key are missing on display.
Looking in DB, they’re missing too, and URL is percent-encoded without extra /.
Source Data and Options screens look about right, at least there’s loads of stuff.
I’m not going to run the import (I did successfully run the new job after it showed).
In ngclient, trying to delete the import seemed to do nothing, but a screen refresh (because I’m having screen update problems even in ngax) showed it got deleted.
Back to ngax and see if I can get a good import and maybe actually try running it.
Looks plausible and runs too. So early ngax test looks good, but what of ngclient?
Still unable to use the Linux versions as I reported before: Release: 2.1.0.111 (Canary) 2025-03-15 - #9 by Taomyn although this time it was RPi-OS for ARM64.
root@ziff:/home/pi# duplicati-server-util change-password
Connecting to http://127.0.0.1:8200/...
Failed to obtain a signin token: Could not load file or assembly 'Microsoft.IdentityModel.Abstractions, Version=7.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. The system cannot find the file specified.
Enter server password:
root@ziff:/home/pi#
Nothing I do allows me to log in with the original server password or to change it, but at least the installation isn’t messing with /etc/default/duplicati so my service settings stay put.
As for Windows, I updated the server I was having S3 issues with, no password problems here, and I started by running a repair on the local backup job first - this one has been fine so far. This is what was reported:
  "MainOperation": "Repair",
  "RecreateDatabaseResults": null,
  "ParsedResult": "Warning",
  "Interrupted": false,
  "Version": "2.1.0.112 (2.1.0.112_canary_2025-03-26)",
  "EndTime": "2025-03-27T07:30:53.2239133Z",
  "BeginTime": "2025-03-27T07:30:18.3719415Z",
  "Duration": "00:00:34.8519718",
  "MessagesActualLength": 4,
  "WarningsActualLength": 1,
    "2025-03-27 08:30:19 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Repair has started",
    "2025-03-27 08:30:50 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started:  ()",
    "2025-03-27 08:30:53 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed:  (2.131 KiB)",
    "2025-03-27 08:30:53 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: QuotaInfo - Started:  ()"
  "Warnings": [
    "2025-03-27 08:30:53 +01 - [Warning-Duplicati.Library.Main.Operation.RepairHandler-LargeEmptyIndexFile]: The empty index file Duplicati.Library.Main.Database.LocalRepairDatabase+RemoteVolume is larger than expected, choosing not to delete it"
  "Errors": [],
    "RemoteCalls": 2,
    "BytesUploaded": 0,
    "BytesDownloaded": 0,
    "FilesUploaded": 0,
    "FilesDownloaded": 0,
    "FilesDeleted": 0,
    "RetryAttempts": 0,
    "UnknownFileSize": 0,
    "UnknownFileCount": 0,
    "KnownFileCount": 2182,
    "KnownFileSize": 75906906142,
    "KnownFilesets": 27,
    "LastBackupDate": "2025-03-17T12:56:34+01:00",
    "BackupListCount": 27,
    "TotalQuotaSpace": 13194072424448,
    "FreeQuotaSpace": 3769860030464,
    "AssignedQuotaSpace": -1,
    "BeginTime": "2025-03-27T07:30:18.3721948Z",
    "Errors": null
No idea what this means or if I should be concerned - I’ll hold on doing anything more for now.
Assuming you refer to the Warning, that got me to look above at release note again, because I was wondering why my backup didn’t delete empty index files, but I read:
and had forgotten the last two words. Running Repair, the expected deletes worked:
Mar 27, 2025 7:42 AM: The operation Repair has completed
Mar 27, 2025 7:42 AM: Backend event: Delete - Completed: duplicati-if679a4ad43af45d7bfb86911f252a50b.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Started: duplicati-if679a4ad43af45d7bfb86911f252a50b.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Completed: duplicati-if0a11ed1fba04f58a22e55e800afd521.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Deleting empty index file Duplicati.Library.Main.Database.LocalRepairDatabase+RemoteVolume
Mar 27, 2025 7:42 AM: Backend event: Delete - Started: duplicati-if0a11ed1fba04f58a22e55e800afd521.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Completed: duplicati-ie7a84e51d32947a393669ae22c5ba364.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Started: duplicati-ie7a84e51d32947a393669ae22c5ba364.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Completed: duplicati-i75576376d94f400797a6f15ae33f0a9a.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Started: duplicati-i75576376d94f400797a6f15ae33f0a9a.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Completed: duplicati-i45874e960e534e6ab9a8a4f5fbf4ae8c.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Started: duplicati-i45874e960e534e6ab9a8a4f5fbf4ae8c.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Completed: duplicati-i293d5c5b08eb4eef87dfd37e0dd910a7.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: Delete - Started: duplicati-i293d5c5b08eb4eef87dfd37e0dd910a7.dindex.zip.aes (541 bytes)
Mar 27, 2025 7:42 AM: Backend event: List - Completed: (536 bytes)
Mar 27, 2025 7:42 AM: Backend event: List - Started: ()
Mar 27, 2025 7:42 AM: The operation Repair has started
My index files were extremely empty, with basically no backup information inside:
so in both the intent looks to be to print a dindex file name. Mine did, yours has something that isn’t even a dindex file name, so maybe some identifier goofed.
Second run of the backup that worked once failed, seemingly on a 60 second timeout.
This version has a default 30 second read-write-timeout (compared to 10m in 2.1.0.5), but maybe it’s still considered good due to other changes? Regardless, I’m at default.
What I’m not at default on is my number-of-retries=0 in order to invite some problems.
Summary of profiling log by showing lines containing Backend:
2025-03-27 10:15:35 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationList]: Starting - RemoteOperationList
2025-03-27 10:15:35 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started:  ()
2025-03-27 10:15:37 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed:  (530 bytes)
2025-03-27 10:15:37 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationList]: RemoteOperationList took 0:00:00:01.865
2025-03-27 10:15:37 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationQuotaInfo]: Starting - RemoteOperationQuotaInfo
2025-03-27 10:15:37 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationQuotaInfo]: RemoteOperationQuotaInfo took 0:00:00:00.000
2025-03-27 10:15:37 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationWaitForEmpty]: Starting - RemoteOperationWaitForEmpty
2025-03-27 10:15:37 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationWaitForEmpty]: RemoteOperationWaitForEmpty took 0:00:00:00.000
2025-03-27 10:19:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 10:19:36 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 10:19:45 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b13e8a7dd6fa9480bbb2e526b3fb564d1.dblock.zip.aes (50.00 MiB)
2025-03-27 10:19:47 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bcbc16412d6a04d7f992ce495fbf79854.dblock.zip.aes (49.96 MiB)
2025-03-27 10:19:59 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 49.96 MiB in 00:00:12.2063091, 4.09 MiB/s
2025-03-27 10:19:59 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bcbc16412d6a04d7f992ce495fbf79854.dblock.zip.aes (49.96 MiB)
2025-03-27 10:19:59 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ifd44d9a54cff452fb25cfa9cb633b69f.dindex.zip.aes (22.68 KiB)
2025-03-27 10:19:59 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 22.68 KiB in 00:00:00.1120708, 202.41 KiB/s
2025-03-27 10:19:59 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-ifd44d9a54cff452fb25cfa9cb633b69f.dindex.zip.aes (22.68 KiB)
2025-03-27 10:19:59 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:26.250
2025-03-27 10:20:05 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 10:20:06 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bece0e7d87b8044d68a5566888024ab3e.dblock.zip.aes (10.67 MiB)
2025-03-27 10:20:07 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 10.67 MiB in 00:00:01.8287084, 5.84 MiB/s
2025-03-27 10:20:07 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bece0e7d87b8044d68a5566888024ab3e.dblock.zip.aes (10.67 MiB)
2025-03-27 10:20:08 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-id76a89bc466144119f95b88874d233c1.dindex.zip.aes (63.36 KiB)
2025-03-27 10:20:08 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 63.36 KiB in 00:00:00.1126734, 562.30 KiB/s
2025-03-27 10:20:08 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-id76a89bc466144119f95b88874d233c1.dindex.zip.aes (63.36 KiB)
2025-03-27 10:20:08 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:02.761
2025-03-27 10:20:14 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 10:20:14 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20250327T141533Z.dlist.zip.aes (958.18 KiB)
2025-03-27 10:20:15 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 958.18 KiB in 00:00:00.8435476, 1.11 MiB/s
2025-03-27 10:20:15 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20250327T141533Z.dlist.zip.aes (958.18 KiB)
2025-03-27 10:20:15 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:01.047
2025-03-27 10:20:46 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:01:10.493
2025-03-27 10:20:46 -04 - [Retry-Duplicati.Library.Main.Backend.Handler-RetryPut]: Operation Put with file duplicati-b13e8a7dd6fa9480bbb2e526b3fb564d1.dblock.zip.aes attempt 1 of 0 failed with message: The operation has timed out.
2025-03-27 10:20:47 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Failed: duplicati-b13e8a7dd6fa9480bbb2e526b3fb564d1.dblock.zip.aes ()
2025-03-27 10:20:47 -04 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerHandlerFailure]: Error in handler: The operation has timed out.
2025-03-27 10:20:47 -04 - [Warning-Duplicati.Library.Main.Backend.DatabaseCollector-FlushingMessagesToLog]: Update: duplicati-20250327T141533Z.dlist.zip.aes State: Uploading Size: 981181 Hash: ivaEIdbYmYnSVLEB3P3/H2WQXTQmFWK9OgWdymAPLWo=
Job log:
 Warnings 2
TimeoutException: The operation has timed out.
Operation: put File: duplicati-20250327T141533Z.dlist.zip.aes Result: {"Size":981181,"Hash":"ivaEIdbYmYnSVLEB3P3/H2WQXTQmFWK9OgWdymAPLWo="}
Update: duplicati-20250327T141533Z.dlist.zip.aes State: Uploaded Size: 981181 Hash: ivaEIdbYmYnSVLEB3P3/H2WQXTQmFWK9OgWdymAPLWo=
 Errors 2
2025-03-27 10:20:47 -04 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
2025-03-27 10:20:47 -04 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed with error: The operation has timed out.
Backblaze web UI for the time of the backup has:
duplicati-20250327T141533Z.dlist.zip.aes (Warning but made it)
duplicati-b13e8a7dd6fa9480bbb2e526b3fb564d1.dblock.zip.aes (timed out but made it)
RemoteOperation table has:
put duplicati-b13e8a7dd6fa9480bbb2e526b3fb564d1.dblock.zip.aes
put duplicati-bcbc16412d6a04d7f992ce495fbf79854.dblock.zip.aes
put duplicati-ifd44d9a54cff452fb25cfa9cb633b69f.dindex.zip.aes
put duplicati-bece0e7d87b8044d68a5566888024ab3e.dblock.zip.aes
put duplicati-id76a89bc466144119f95b88874d233c1.dindex.zip.aes
OK, now try a second backup and see if it can clean up things and succeed…
Still fails on timeout, but in less time. Activity summary from the log file:
2025-03-27 11:27:00 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationList]: Starting - RemoteOperationList
2025-03-27 11:27:00 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started:  ()
2025-03-27 11:27:01 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed:  (536 bytes)
2025-03-27 11:27:01 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationList]: RemoteOperationList took 0:00:00:01.295
2025-03-27 11:27:01 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationQuotaInfo]: Starting - RemoteOperationQuotaInfo
2025-03-27 11:27:01 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationQuotaInfo]: RemoteOperationQuotaInfo took 0:00:00:00.000
2025-03-27 11:27:02 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationWaitForEmpty]: Starting - RemoteOperationWaitForEmpty
2025-03-27 11:27:02 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationWaitForEmpty]: RemoteOperationWaitForEmpty took 0:00:00:00.000
2025-03-27 11:28:09 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 11:28:09 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20250327T141534Z.dlist.zip.aes (958.18 KiB)
2025-03-27 11:28:09 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-if2316671cd3d42798b1ae7d48186b530.dindex.zip.aes (22.81 KiB)
2025-03-27 11:28:10 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 958.18 KiB in 00:00:01.2938010, 740.60 KiB/s
2025-03-27 11:28:10 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20250327T141534Z.dlist.zip.aes (958.18 KiB)
2025-03-27 11:28:10 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:01.799
2025-03-27 11:28:11 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 22.81 KiB in 00:00:01.6136102, 14.13 KiB/s
2025-03-27 11:28:11 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-if2316671cd3d42798b1ae7d48186b530.dindex.zip.aes (22.81 KiB)
2025-03-27 11:28:11 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:01.649
2025-03-27 11:29:09 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 11:29:10 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b5f9bb79bf67d44d993cd7657811dcc79.dblock.zip.aes (50.00 MiB)
2025-03-27 11:29:10 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bef3586058687402a8f556cb38b7213cf.dblock.zip.aes (49.97 MiB)
2025-03-27 11:29:20 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 11:29:20 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b65ec1c6e478c4dc3b18422a75fbe0632.dblock.zip.aes (8.43 MiB)
2025-03-27 11:29:25 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 8.43 MiB in 00:00:05.2113622, 1.62 MiB/s
2025-03-27 11:29:25 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b65ec1c6e478c4dc3b18422a75fbe0632.dblock.zip.aes (8.43 MiB)
2025-03-27 11:29:26 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i22b7cff2eb19460a9144cf918e2a62c0.dindex.zip.aes (53.89 KiB)
2025-03-27 11:29:26 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 53.89 KiB in 00:00:00.6330919, 85.12 KiB/s
2025-03-27 11:29:26 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i22b7cff2eb19460a9144cf918e2a62c0.dindex.zip.aes (53.89 KiB)
2025-03-27 11:29:26 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:06.392
2025-03-27 11:29:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: Starting - RemoteOperationPut
2025-03-27 11:29:33 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20250327T152657Z.dlist.zip.aes (958.22 KiB)
2025-03-27 11:29:34 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 958.22 KiB in 00:00:00.8538193, 1.10 MiB/s
2025-03-27 11:29:34 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20250327T152657Z.dlist.zip.aes (958.22 KiB)
2025-03-27 11:29:34 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:01.028
2025-03-27 11:29:38 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 49.97 MiB in 00:00:27.4970785, 1.82 MiB/s
2025-03-27 11:29:38 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bef3586058687402a8f556cb38b7213cf.dblock.zip.aes (49.97 MiB)
2025-03-27 11:29:38 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ied44d06a4ad342908644ce2c3bedc6dd.dindex.zip.aes (22.73 KiB)
2025-03-27 11:29:38 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 22.73 KiB in 00:00:00.1280924, 177.46 KiB/s
2025-03-27 11:29:38 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-ied44d06a4ad342908644ce2c3bedc6dd.dindex.zip.aes (22.73 KiB)
2025-03-27 11:29:38 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:28.921
2025-03-27 11:29:55 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Backend.Handler-RemoteOperationPut]: RemoteOperationPut took 0:00:00:45.804
2025-03-27 11:29:55 -04 - [Retry-Duplicati.Library.Main.Backend.Handler-RetryPut]: Operation Put with file duplicati-b5f9bb79bf67d44d993cd7657811dcc79.dblock.zip.aes attempt 1 of 0 failed with message: The operation has timed out.
2025-03-27 11:29:55 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Failed: duplicati-b5f9bb79bf67d44d993cd7657811dcc79.dblock.zip.aes ()
2025-03-27 11:29:59 -04 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerHandlerFailure]: Error in handler: The operation has timed out.
2025-03-27 11:29:59 -04 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeWhileActive]: Terminating 1 active uploads
2025-03-27 11:29:59 -04 - [Warning-Duplicati.Library.Main.Backend.Handler-BackendManagerDisposeError]: upload was active during termination, but completed successfully
2025-03-27 11:29:59 -04 - [Warning-Duplicati.Library.Main.Backend.DatabaseCollector-FlushingMessagesToLog]: Update: duplicati-20250327T152657Z.dlist.zip.aes State: Uploading Size: 981213 Hash: Zc+xSN+gA6I1htJwdpMzG7JG4TK6R+uwMQi1Dd/4nh4=
I thought I’d try BackendTester before tweaking read-write-timeout, but it did its own. Is this really a good representation of what an actual backup would use for timeout?
3/27/2025 12:19:21 PM
[12:19:21 616] Starting run no 4
[12:19:22 530] Read Write Timeout set to infinite (because implements ITimeoutExemptBackend)
[12:19:22 531] Generating file 0 (19.00 MiB)
[12:19:22 758] Generating file 1 (37.92 MiB)
[12:19:23 182] Generating file 2 (13.39 MiB)
[12:19:23 333] Generating file 3 (47.08 MiB)
[12:19:23 855] Generating file 4 (10.00 MiB)
[12:19:23 974] Generating file 5 (8.70 MiB)
[12:19:24 110] Generating file 6 (2.50 MiB)
[12:19:24 151] Generating file 7 (28.57 MiB)
[12:19:24 496] Generating file 8 (37.16 MiB)
[12:19:24 993] Generating file 9 (24.78 MiB)
[12:19:25 308] Uploading wrong files ...
[12:19:25 308] Generating file 10 (1.56 KiB)
[12:19:25 319] Uploading file 0, 1.56 KiB ...  done! in 558 ms
[12:19:25 878] Uploading file 0, 1.56 KiB ...  done! in 290 ms
[12:19:26 169] Uploading file 9, 1.56 KiB ...  done! in 247 ms
[12:19:26 418] Uploading files ...
[12:19:26 418] Uploading file 0, 19.00 MiB ...  done! in 7530 ms
[12:19:33 949] Uploading file 1, 37.92 MiB ...  done! in 28094 ms
[12:20:02 043] Uploading file 2, 13.39 MiB ...  done! in 11229 ms
[12:20:13 273] Uploading file 3, 47.08 MiB ... [12:20:44 763] Failed to upload file 3, error message: System.TimeoutException: The operation has timed out.
   at Duplicati.StreamUtil.TimeoutObservingStream.ReadImplAsync(Byte[] buffer, Int32 offset, Int32 count, CancellationToken cancellationToken)
   at System.IO.Stream.<>c.<BeginReadInternal>b__38_0(Object <p0>)
   at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread)
   at System.IO.Stream.<CopyToAsync>g__Core|27_0(Stream source, Stream destination, Int32 bufferSize, CancellationToken cancellationToken)
   at System.Net.Http.StreamToStreamCopy.<CopyAsync>g__DisposeSourceAsync|1_0(Task copyTask, Stream source)
   at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask)
   at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnection.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
   at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
   at Duplicati.Library.Backend.Backblaze.B2.PutAsync(String remotename, Stream stream, CancellationToken cancelToken)
   at Duplicati.CommandLine.BackendTester.Program.Uploadfile(String localfilename, Int32 i, String remotefilename, IBackend backend, Boolean disableStreaming, Int64 throttle, Int32 readWriteTimeout), remote name: yyBNPiiTQNNBCPSikwlAfR after 31563 ms
[12:20:44 840] Uploading file 4, 10.00 MiB ...  done! in 2868 ms
[12:20:47 709] Uploading file 5, 8.70 MiB ...  done! in 3508 ms
[12:20:51 218] Uploading file 6, 2.50 MiB ...  done! in 2436 ms
[12:20:53 655] Uploading file 7, 28.57 MiB ...  done! in 23314 ms
[12:21:16 970] Uploading file 8, 37.16 MiB ...  done! in 24095 ms
[12:21:41 066] Uploading file 9, 24.78 MiB ...  done! in 15139 ms
EDIT 3:
Going to an infinite read-write-timeout (0s) seems to have solved the upload fails.
Recovery code seems to have managed to deal with the mess, so good job there.
But why does Canary continue to suffer? This was asked before. Response was:
If there’s no need, then why does it fail by default with small destination (561 files)?
Warnings on GUI Restore when picking a time (including default newest):
NGAX
ngclient is not very good at showing errors, but the job log has a warning:
“2025-03-27 19:48:03 -04 - [Warning-Duplicati.Library.Main.Controller-OptionValidationError]: The value "20250327T234803Z" supplied to --time does not represent a valid time”
and if you go back to ngax, some warning popups are awaiting you there…
is presumably the “Added support for sorting the list of backups in the UI”.
I initially couldn’t find it in the UI, but refresh put it in the upper right corner.
It’s very fragile though, e.g. if you change page and return home, it’s gone.
Further to my previous report, I went ahead and tried the S3 backup again, this time I got:
    "2025-03-28 08:54:26 +01 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed with error: Detected 306 file(s) in FilesetEntry without corresponding FileLookup entry in the following filesets:\r\nFileset 2: 10/03/2025 05:20:13 (id = 11)\r\nDatabaseInconsistencyException: Detected 306 file(s) in FilesetEntry without corresponding FileLookup entry in the following filesets:\r\nFileset 2: 10/03/2025 05:20:13 (id = 11)"
So I ran a repair and got:
    "2025-03-28 08:57:19 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Repair has started",
    "2025-03-28 08:57:19 +01 - [Information-Duplicati.Library.Main.Operation.RepairHandler-RepairingBrokenFilesets]: Repairing 1 broken filesets",
    "2025-03-28 08:57:19 +01 - [Information-Duplicati.Library.Main.Operation.RepairHandler-RepairingBrokenFileset]: Repairing broken fileset 1 of 1: 10/03/2025 05:20:13",
    "2025-03-28 08:57:19 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-20250310T042013Z.dlist.zip.aes (4.234 MiB)",
    "2025-03-28 08:57:21 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-20250310T042013Z.dlist.zip.aes (4.234 MiB)",
    "2025-03-28 08:57:33 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started:  ()",
    "2025-03-28 08:57:35 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed:  (15.673 KiB)"
  "Warnings": [
    "2025-03-28 08:57:35 +01 - [Warning-Duplicati.Library.Main.Operation.RepairHandler-LargeEmptyIndexFile]: The empty index file Duplicati.Library.Main.Database.LocalRepairDatabase+RemoteVolume is larger than expected, choosing not to delete it",
I then re-ran the S3 backup which then worked fine. A repair afterwards then showed:
 "Warnings": [
    "2025-03-28 11:08:28 +01 - [Warning-Duplicati.Library.Main.Operation.RepairHandler-LargeEmptyIndexFile]: The empty index file Duplicati.Library.Main.Database.LocalRepairDatabase+RemoteVolume is larger than expected, choosing not to delete it",
For the local backup job, it ran fine, but for curiosity I ran a repair on it and it logged:
  "Warnings": [
    "2025-03-28 08:58:19 +01 - [Warning-Duplicati.Library.Main.Operation.RepairHandler-LargeEmptyIndexFile]: The empty index file Duplicati.Library.Main.Database.LocalRepairDatabase+RemoteVolume is larger than expected, choosing not to delete it"
I’m still not sure what I’m supposed to do about these index files which it chooses not to delete.
Not sure how to deal with it going forward, since the commits are in a different repo.
But there was no additional fixes to ngclient for this round.
We are working on it. I have added your findings as issues.
I see there is a bug that prevents you from seeing the filename. The feature is a new cleanup that identifies leftover index files and removes them. According to the database they contain no needed information so they can be safely deleted.
I will fix the issue preventing the name from being displayed, so we can see what file it is.
It does not have any negative impact, but it does give a warning on each run.
I see that part needs to be fixed. The ITimeoutExemptBackend was used for the timeout system prior to this release but should not be used anymore.
The read-write-timeout is not an upload timeout, it is an inactivity timeout. Every time some data is processed, the timer is reset. So a default of 30 seconds means that not even a single byte was processed for 30 seconds, which would indicate a stalled connection IMO.
This looks like it timed out after 45 seconds. Any clue as to why it would time out? Network issues?
We can increase the timeout to 60s by default, but it should not be required.
:1st_place_medal:
Fixed one parsing error, but apparently created a new one.
I have registered an issue.
No, that is a good point. They should be deleted, so perhaps I should just update the code to delete them anyway. They serve no purpose anymore.
Unlike with 2.1.0.111, I get the following message with SharePoint backup targets:
2025-03-28 04:00:00 +01 - [Warning-Duplicati.Library.Main.Controller-UnsupportedOption]: The specified option --site-id is not supported and will be ignored.
It seems, however, that the backup is working.
Options from AdditionalSupportedCommands seem gone (per help) , so also:
onedrivev2 has lost drive-id
msgroup has lost group-id and group-email
I didn’t find where that is. You mean https://docs.duplicati.com/?
What does that mean? With the option I get the warning, but the backup seems to work. Without the option, access to SharePoint doesn’t work.
Via the CLI can site-id be used? SharePoint v2 (Graph API) | Duplicati
I’m confused. :slight_smile:
It means it’s also gone from Duplicati.CommandLine help, e.g. for onedrivev2 or msgroup.
Interesting result. I didn’t think Duplicati could process options it didn’t know, but maybe it can.
The AdditionalSupportedCommands reference is code. That part wasn’t really written for you.
Good catch, it has been fixed for next canary.
We have been having some trouble reproducing this.
Can you share how you created the file?
Also, can you share an example file for this?
Windows 10, Edge, probably from Canary, probably from ngax, encrypted.
Repro, maybe not minimal, but likely close:
2.1.0.112 in ngax
Add a new backup
Name one two
No encryption
B2 cloud storage
my-bucket
Path one two
ID 0000000000000000000000000
Key K000000000000000000000000000000
Source C:\backup source\short.txt
No schedule
Save
Export to file, with passwords, unencrypted
Switch to new ngclient UI
Import from file
Click Destination
one two-duplicati-config.zip (604 Bytes)
  "CreatedByVersion": "2.1.0.112",
  "Schedule": null,
  "Backup": {
    "ID": "5",
    "Name": "one two",
    "Description": "",
    "Tags": [],
    "TargetURL": "b2://my-bucket/one two?auth-username=0000000000000000000000000\u0026auth-password=K000000000000000000000000000000",
    "DBPath": "C:\\Duplicati\\duplicati-2.1.0.112_canary_2025-03-26-win-x64-gui\\RUN\\AJDCOZJTKP.sqlite",
    "Sources": [
      "C:\\backup source\\short.txt"
    "Settings": [
        "Filter": "",
        "Name": "encryption-module",
        "Value": "",
        "Argument": null
        "Filter": "",
        "Name": "compression-module",
        "Value": "zip",
        "Argument": null
        "Filter": "",
        "Name": "dblock-size",
        "Value": "50mb",
        "Argument": null
        "Filter": "",
        "Name": "passphrase",
        "Value": "",
        "Argument": null
        "Filter": "",
        "Name": "--no-encryption",
        "Value": "true",
        "Argument": null
    "Filters": [],
    "Metadata": {},
    "IsTemporary": false
  "DisplayNames": {
    "C:\\backup source\\short.txt": "short.txt"
Using developer tools, this is what comes over to backups request from refresh:
"TargetURL": "b2://my-bucket/one two?auth-username=0000000000000000000000000&auth-password=K000000000000000000000000000000",
If I return to ngax, things look OK. Note that I never actually saved from ngclient.
Hi, just a few issues, which were working, but have been lately broken with canaries:
TLS is broken
FTPS doesn’t work with Filezilla, because TLS session resumption data is missing. It seems that it authenticates data connections as well, which is good for security.
Code: 425 Message: Unable to build data connection: TLS session of data connection not resumed. => Code: 425 Message: Unable to build data connection: TLS session of data connection not resumed.
Transactions are broken
Even if encryption is disabled, then there’s transaction error:
code = Unknown (-1), message = System.Data.SQLite.SQLiteException (0x80004005): unknown error
No transaction is active on this connection
at System.Data.SQLite.SQLiteTransactionBase.IsValid(Boolean throwError)
at System.Data.SQLite.SQLiteTransaction.Commit()
at Duplicati.Library.Main.Database.ReusableTransaction.Commit(String message, Boolean restart)
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync(String sources, IBackendManager backendManager, IFilter filter)
at Duplicati.Library.Main.Controller.<>c__DisplayClass22_0.<b__0>d.MoveNext()
— End of stack trace from previous location —
at Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Func3 method) at Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter) at Duplicati.CommandLine.Commands.Backup(TextWriter outwriter, Action1 setup, List1 args, Dictionary2 options, IFilter filter)
at Duplicati.CommandLine.Program.ParseCommandLine(TextWriter outwriter, Action1 setup, Boolean& verboseErrors, String[] args) at Duplicati.CommandLine.Program.RunCommandLine(TextWriter outwriter, TextWriter errwriter, Action1 setup, String args)
— Verification output is confusing, completed or failed —
Downloading file duplicati-20250408T070506Z.dlist.zip.aes (1,06 KiB) …
Downloading file duplicati-i58942b3bd5ed4426b2c39dd6b0874587.dindex.zip.aes (1,01 KiB) …
Downloading file duplicati-bd24d56c698cc4f58ab00d057c7ce6d00.dblock.zip.aes (1,47 KiB) …
Fatal error => unknown error
Operation: get File: duplicati-20250408T070506Z.dlist.zip.aes Result: {“Size”:1085,“Hash”:“P9inMH1suprRW1VJaVQDhDXHUoEDMSkwnKIaUTU/n8c=”}
Operation: get File: duplicati-i58942b3bd5ed4426b2c39dd6b0874587.dindex.zip.aes Result: {“Size”:1037,“Hash”:“iR3ZCw7lEmXPJY\u002BkaNkE6Y4HWCfU3lIbhSb765auo0g=”}
Operation: get File: duplicati-bd24d56c698cc4f58ab00d057c7ce6d00.dblock.zip.aes Result: {“Size”:1501,“Hash”:“5jWfz8VSQ9sPbodg4020IzMtr/5pHjmJwkIrvxmWcE4=”}
Toimenpide Backup ep?onnistui. Virheilmoitus oli: unknown error
No transaction is active on this connection => unknown error
Is this just on FTP? There was a bug/fix on a report of FTP leaving connections open, but the fix was actually in BackendManager. Bug might exist but be hard to notice elsewhere.
Regardless, I’m not seeing this on local folder or Backblaze B2 backups done in the GUI.
A different regression new to 2.1.0.112 that has gotten a second report is one I can repro:
Restore time error after upgrade
First report below had me wondering if this was the locale-sensitive time parsing issue/fix:
Second report and my own testing on en-US GUI setting and CLI makes me doubt that.
My popup shows up when I open Restore in GUI, with or without restore-legacy true.
Interestingly, with GUI Commandline restore, whatever’s going wrong doesn’t happen.
Poking further with Export As Command-line, the help text for time gives me examples.
Duplicati supports absolute and relative dates and times:
  now --> The current time
  1234567890 --> A timestamp, seconds since 1970.
  "2009-03-26T08:30:00+01:00" --> An absolute date and time. You can also use the local date and time format of your system like e.g. "01-14-2000" or "01 jan. 2004".
  Y, M, D, W, h, m, s --> Relative date and time: year, month, day, week, hour, minute, second. Example: 2M10D5h is now + 2 months + 10 days + 5 hours.
All work in 2.1.0.111 restore with time option, as does the style posted above. 2.1.0.112:
now fail
1234567890 pass
2009-03-26T08:30:00+01:00 fail
2M10D5h pass
20250328T131220Z fail
I’m not testing for proper interpretation, just for whether ot not option value gets rejected.
It’s not like 2.1.0.111 lets in everything, but there seems to be two levels which might fail:
Restore started at 4/10/2025 10:35:24 AM
The value "wrong" supplied to --time does not represent a valid time
Checking remote backup ...
  Listing remote folder ...
The operation Restore has failed with error: Unparsed data: wrong => Unparsed data: wrong
System.Exception: Unparsed data: wrong
   at Duplicati.Library.Utility.Timeparser.ParseTimeInterval(String datestring, DateTime offset, Boolean negate)
   at Duplicati.Library.Utility.Timeparser.ParseTimeInterval(String datestring, DateTime offset)
   at Duplicati.Library.Main.Options.get_Time()
   at Duplicati.Library.Main.Operation.RestoreHandler.PrepareBlockAndFileList(LocalRestoreDatabase database, Options options, IFilter filter, RestoreResults result)
   at Duplicati.Library.Main.Operation.RestoreHandler.DoRunNewAsync(IBackendManager backendManager, LocalRestoreDatabase database, IFilter filter, CancellationToken cancellationToken)
   at Duplicati.Library.Main.Operation.RestoreHandler.RunAsync(String[] paths, IBackendManager backendManager, IFilter filter)
   at Duplicati.Library.Main.Controller.<>c__DisplayClass23_0.<<Restore>b__0>d.MoveNext()
   at Duplicati.Library.Main.Controller.Restore(String[] paths, IFilter filter)
   at Duplicati.CommandLine.Commands.Restore(TextWriter outwriter, Action`1 setup, List`1 args, Dictionary`2 options, IFilter filter)
   at Duplicati.CommandLine.Program.ParseCommandLine(TextWriter outwriter, Action`1 setup, Boolean& verboseErrors, String[] args)
The complaint which has gotten touchy in 2.1.0.112 is the first style, maybe a pre-check.
I see I reported this myself here using an image, two weeks ago, but here’s more testing.
Thanks for reporting, I have created an issue for this.
This is a bug of sorts in SQLite bindings. If you create a transaction and then commit it (without any operation done in the transaction) it gives this error. So somewhere Duplicati is starting a transaction but ends up not needing it, and this failure happens.
Do you know when it happens? We have quite a few CI tests that covers a wide variety of setups and none of them trigger it, so I need some kind of hint to figure out when it happens.
Hard to say, but it looks like it completes, and then the final flushing of messages to the database fails due to this error.
Yes, it is a pre-check that fails because the --time can be both a relative time and an absolute time. All the other options are one or the other. I added a new commandline argument type to 2.1.0.113 to work around this issue.
I believe its this PR you are talking about. I don’t think the FPTS issue is related. If anything it should bring more stability/memory leak guard for all other backends as it properly disposes all pooled backend instances once the operation is complete.
I will try to replicated FTPS issue soon, the server environment I had setup is with FileZila on Windows 11.
