Tiny backup while trying to reproduce restore problem of uncreated folders has stuck status.
Iāve seen other small backups stick at Backup complete!, but itās rare. Maybe time for report.
Profiling log ends with:
2024-12-26 08:16:05 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-b369beed73efa4bc29e5add7e7a5e28f1.dblock.zip (1.42 KB)
2024-12-26 08:16:05 -05 - [Profiling-Duplicati.Library.Main.BackendManager-DownloadSpeed]: Downloaded 1.42 KB in 00:00:00.0010016, 1.38 MB/s
2024-12-26 08:16:05 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-b369beed73efa4bc29e5add7e7a5e28f1.dblock.zip (1.42 KB)
2024-12-26 08:16:05 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.BackendManager-RemoteOperationGet]: RemoteOperationGet took 0:00:00:00.001
2024-12-26 08:16:05 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: UPDATE "RemoteVolume" SET "VerificationCount" = MAX(1, CASE WHEN "VerificationCount" <= 0 THEN (SELECT MAX("VerificationCount") FROM "RemoteVolume") ELSE "VerificationCount" + 1 END) WHERE "Name" = "duplicati-b369beed73efa4bc29e5add7e7a5e28f1.dblock.zip"
2024-12-26 08:16:06 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: UPDATE "RemoteVolume" SET "VerificationCount" = MAX(1, CASE WHEN "VerificationCount" <= 0 THEN (SELECT MAX("VerificationCount") FROM "RemoteVolume") ELSE "VerificationCount" + 1 END) WHERE "Name" = "duplicati-b369beed73efa4bc29e5add7e7a5e28f1.dblock.zip" took 0:00:00:00.123
2024-12-26 08:16:06 -05 - [Information-Duplicati.Library.Main.Operation.TestHandler-Test results]: Successfully verified 3 remote files
2024-12-26 08:16:06 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "LogData" WHERE "Timestamp" < 1732626966
2024-12-26 08:16:06 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "LogData" WHERE "Timestamp" < 1732626966 took 0:00:00:00.000
2024-12-26 08:16:06 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "RemoteOperation" WHERE "Timestamp" < 1732626966
2024-12-26 08:16:06 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "RemoteOperation" WHERE "Timestamp" < 1732626966 took 0:00:00:00.000
2024-12-26 08:16:06 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: PRAGMA optimize
2024-12-26 08:16:06 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: PRAGMA optimize took 0:00:00:00.004
2024-12-26 08:16:06 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Controller-RunBackup]: Running Backup took 0:00:00:07.555
2024-12-26 08:16:06 -05 - [Information-Duplicati.Library.Main.Controller-CompletedOperation]: The operation Backup has completed
Status bar says Running task: Backup complete!
Server poll maybe explains why status bar says that, but is server confused?
GET /api/v1/progressstate HTTP/1.1
Host: localhost:8200
Connection: keep-alive
sec-ch-ua-platform: "Windows"
Authorization: Bearer REDACTED
Cache-Control: no-cache
Pragma: no-cache
sec-ch-ua: "Microsoft Edge";v="131", "Chromium";v="131", "Not_A Brand";v="24"
sec-ch-ua-mobile: ?0
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36 Edg/131.0.0.0
Accept: application/json, text/plain, */*
Sec-Fetch-Site: same-origin
Sec-Fetch-Mode: cors
Sec-Fetch-Dest: empty
Referer: http://localhost:8200/ngax/index.html
Accept-Encoding: gzip, deflate, br, zstd
Accept-Language: en-US,en;q=0.9
Cookie: default-theme=ngax
HTTP/1.1 200 OK
Content-Type: application/json; charset=utf-8
Date: Thu, 26 Dec 2024 13:32:19 GMT
Server: Kestrel
Transfer-Encoding: chunked
{"BackupID":"4","TaskID":75,"BackendAction":"Get","BackendPath":"duplicati-b369beed73efa4bc29e5add7e7a5e28f1.dblock.zip","BackendFileSize":1454,"BackendFileProgress":1454,"BackendSpeed":1,"BackendIsBlocking":false,"CurrentFilename":null,"CurrentFilesize":0,"CurrentFileoffset":0,"CurrentFilecomplete":false,"Phase":"Backup_Complete","OverallProgress":1,"ProcessedFileCount":1,"ProcessedFileSize":17,"TotalFileCount":1,"TotalFileSize":17,"StillCounting":false}
Because itās hard to trace Wireshark to a specific tab, hereās the view from the offending tab:
āBackupIDā: ā4ā,
āTaskIDā: 75,
āBackendActionā: āGetā,
āBackendPathā: āduplicati-b369beed73efa4bc29e5add7e7a5e28f1.dblock.zipā,
āBackendFileSizeā: 1454,
āBackendFileProgressā: 1454,
āBackendSpeedā: 0,
āBackendIsBlockingā: false,
āCurrentFilenameā: null,
āCurrentFilesizeā: 0,
āCurrentFileoffsetā: 0,
āCurrentFilecompleteā: false,
āPhaseā: āBackup_Completeā,
āOverallProgressā: 1,
āProcessedFileCountā: 1,
āProcessedFileSizeā: 17,
āTotalFileCountā: 1,
āTotalFileSizeā: 17,
āStillCountingā: false
About ā System information
Server state properties
- lastEventId : 373
- lastDataUpdateId : 102
- lastNotificationUpdateId : 12
- estimatedPauseEnd : ā0001-01-01T04:56:02.000Zā
- activeTask : {āItem1ā:74,āItem2ā:null}
- programState : Running
- lastErrorMessage :
- connectionState : connected
- connectionAttemptTimer : 0
- failedConnectionAttempts : 0
- failedAuthAttempts : 0
- lastPgEvent : {āBackupIDā:ā4ā,āTaskIDā:75,āBackendActionā:āGetā,āBackendPathā:āduplicati-b369beed73efa4bc29e5add7e7a5e28f1.dblock.zipā,āBackendFileSizeā:1454,āBackendFileProgressā:1454,āBackendSpeedā:0,āBackendIsBlockingā:false,āCurrentFilenameā:null,āCurrentFilesizeā:0,āCurrentFileoffsetā:0,āCurrentFilecompleteā:false,āPhaseā:āBackup_Completeā,āOverallProgressā:1,āProcessedFileCountā:1,āProcessedFileSizeā:17,āTotalFileCountā:1,āTotalFileSizeā:17,āStillCountingā:false}
- updaterState : Waiting
- updateDownloadLink : https://updates.duplicati.com/canary/duplicati-2.1.0.103_canary_2024-12-21-win-x64-gui.zip
- updatedVersion : 2.1.0.103
- updateDownloadProgress : 0
- proposedSchedule : [{āItem1ā:ā2ā,āItem2ā:ā2024-12-27T12:20:00Zā}]
- schedulerQueueIds :
- pauseTimeRemain : 0
Thereās nothing after the backup itself such as a notification or a script (which can cause this).
EDIT 3:
Edge wanted an update, and this got status bar back to normal, but Duplicati is still confused.
Tray icon is still busy
but I think this is the 401 unauthorized bug, or at least if I trace one back from Wireshark and compare its port to netstat -ano | findstr 8200, itās on TrayIcon port so that may explain.
Back on the tab, I can click Run and watch it go in, get 200 OK, but not see status bar update, despite a log being created. This is unusual, but backup is fast. A slow one shows same thing.
Refresh of browser clears it up. Iām not sure how such glitches arise, but refresh often helpsā¦
EDIT 4:
I likely must restart Duplicati to get its TrayIcon longpoll āHTTP/1.1 401 Unauthorizedā fixed. Fiddling around in the tab with hard refresh and logout/login is still leaving this TrayIcon failing.
Fiddling around in the TrayIcon with Pause and Open can open a new tab but not fix TrayIcon.
